Old 02-23-2013, 08:36 AM   #21
CA_Tallguy's Avatar
1977 31' Excella 500
Zavalla , Texas
Originally Posted by Crusty View Post
Professional boat coaters often build up the bulk of a coating with Rapid Clear and then finish with three coats of the original premium for UV protection.
I've read this suggestion a number of places and have been thinking along these lines. Except I thought the rapid coat with the tint might help the woodwork look a little more vintage. (For those who don't know, the rapidcoat and rapidclear are identical except for a light tint in the former.)
If you like the satin finish, Wipe On polyurethane is much easier to apply and is very durable except that it has no UV protection.
Doh! That was my dads suggestion at the outset! I was thinking the rapid coat/clear might be a similar proposition - both products are thin and supposedly easy to apply but the epifanes has the epifanes name and reputation so I was going the premium route. I also was thinking the epifanes might be better for moisture?
WBCCI #1711
Texas Gulf Coast Unit, Texas Airstream Harbor
Angelina National Forest, Zavalla, TX
CA_Tallguy is offline   Reply With Quote
Old 02-23-2013, 09:01 AM   #22
Crusty's Avatar
1992 34' Excella
The bottom line on all varnishes is that the more suspended solids a varnish has in it, the better UV protection it has. The darkest varnishes provide the best UV protection and Epiphanes premium is their darkest product.
Epiphanes is really way over kill for what you're doing. Inside of a trailer you don't need the extreme environmental resistance of it, and the application of it will be an experience that you will never forget. You don't need to protect the wood from hurricanes and direct sunlight, just normal household moisture.
Thinking about it some more, inside of a trailer I would use old time shellac flakes cut with alcohol. It looks great, protects the wood well, is easier and quicker to apply, and can be touched up at any time in the future by wetting a brush in alcohol and reflowing the surface. Shellac has been around longer than Epiphanes and has a good reputation too.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Old 02-23-2013, 09:13 AM   #23
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
I would use something other than shellac right around the bar, though - spilled alcohol does leave a mark .
I agree that using high end tropic-rated varnishes inside our trailers isn't necessary. With the possible exception of any wall area adjacent to the door, we just don't get UV exposure inside the trailer, so interior finishes work just fine.
Having finishes that are readily repaired is important for many; trailers get used, and sometimes finishes get damaged. I use a traditional oil finish on our 19' steam launch; it does mean at least yearly rubdowns with more oil, but it's readily repaired and easily applied.
We're just in the process of putting in butcher block counters in our 1971; those will have an oil finish since I want them to be food-safe.
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
Old 02-23-2013, 09:40 AM   #24
CA_Tallguy's Avatar
Zavalla , Texas
Oh my ... Now you've started to convince me that my assumptions thus far are off the mark quite a bit. Is rapidclear/coat really all that more difficult to use than wipe on poly? I thought I might get three or four coats down with it then decide if I want to go further with it or something else. With 6 hours between coats, I can do four coats in two days. And product info seems to indicate that may be sufficient to leave it like that if I want to (four coats or so). It is thin like wipe on poly, apparently, so I was thinking the effort would be similar but end result superior. And I felt like I might have more options to go further after the base should I decide to do that, or for future maintenance.
Are these assumptions incorrect?
WBCCI #1711
Old 02-23-2013, 09:45 AM   #25
Crusty's Avatar
1992 34' Excella
- Bart
Oh, that's right. I don't drink these days and that never occurred to me.
Crusty
Lake Travis, TX
"Rancho Deluxe"
Old 02-23-2013, 10:09 AM   #26
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I used gloss Minwax oil polyurethane on our house kitchen cabinets (hickory, no stain), 13 years ago. The finish is durable and still looks great through 2 sets of small grandchildren living here the whole time. In the Airstream, I used gloss poly in the bathroom (because I grabbed the wrong can), but satin on everything else (because I grabbed the right can). It's Minwax fast dry oil poly, and I am happy with the finish so far. It's a 4 hour dry time between coats, usually. I have done wipe on in the past, but I always reach for a brush nowadays. You can put the brush in a sealed ziplock bag, throw in the freezer between coats. Just let it thaw out before you use it for about 15 min. There's lots of options out there. Pick one you like!
Kay
Old 02-23-2013, 11:01 AM   #27
ddruker's Avatar
1999 27' Safari
Palo Alto , California
Sounds like you are planning to do your finishing inside the trailer.
Couple of thoughts:
Make up some sample pieces of wood in the different gloss finishes you are considering - so you can see what they look like in the trailer before you commit yourself. I prefer satin or semi for my trailer.
Cleanliness is super important - any little spec of dust will cause visible imperfections in your finish - so make sure that you wipe down your surfaces with a tack cloth and ideally also wipe down with a lint-free rag dipped in mineral spirits - it's important to do this both after your sanding and in between coats.
If you don't have too much surface area - one trick that may help is to use a spray can for your final coat. You can do as many brush on or wipe on coats as you want to build the thickness of finish you want, do a very light sanding with 800 grit paper to smooth out any last dust bunnies, wipe down, and then do a finish coat by spraying. This leads to as close to a perfect finish as you can probably achieve without removing your cabinetry from the trailer.
Spray cans of shellac, lacquer and polyurethane are available at the big box stores.
I find the new poly finishes to work well, and they are hard enough to use on horizontal surfaces like tabletops. I mostly finish cabinets with lacquer because of the very fast drying time, but I do this in my shop and spray using an HVLP setup - I wouldn't do this inside the trailer because of fumes and overspray. I use poly for areas that need to be wear resistant - like table and counter tops.
- Dan
1999 27' Airstream Safari + 2011 Mercedes GL 350 Turbo-diesel + 2021 Ford F150 Platinum Hybrid w/ 7,200 Watt Pro Power
ddruker is offline   Reply With Quote
Old 02-23-2013, 12:48 PM   #28
Crusty's Avatar
1992 34' Excella
I've heard a story of one extreme varnisher who builds a totally enclosed varnishing room out of plastic sheet complete with positive pressure entry air lock and a laminar flow downdraft air hepafilter system in the varnishing chamber, then enters the lock freshly showered and completely naked where he puts on a full clean room suit and varnishes only at night with no one else around and classical music playing in the background. Personally I think that's taking it much too far and I'm willing to accept some imperfections in my finishes in the interest of actually completing the project.
A problem with varnish is that those small bits of the world around us get trapped and show up in the finish if you look close enough. A really good varnish job looks slick and shiny, an eighth of an inch deep and beautiful but that comes with a significant amount of prep, attention to detail and a good technique. Le Tonkinois is more forgiving and easier to apply than Epiphanes, but polyurethane is easier still and I think the MinWax products recommended above are an overall good choice.
Varnishing vertical surfaces can be even more challenging because the varnish wants to sag until it hardens.
Crusty
Lake Travis, TX
"Rancho Deluxe"
Old 02-24-2013, 09:40 AM   #29
Minno's Avatar
1972 31' Sovereign
If someone is looking that hard at my finishes, I'll kick them out of the trailer!
Kay
Old 03-24-2013, 01:23 PM   #30
Ramble On's Avatar
2004 28' International CCD
rockwall , Texas
Best product to use ,General Finishes Arm R Seal, mixture of tung oil and urethane
Ramble On is offline   Reply With Quote
Old 03-24-2013, 04:26 PM   #31
1979 Argosy Minuet 7.3 Metre
Topping , Virginia
All of the above info is good, or most of it. I'm not about to disparage anyone who has experienced success with a particular product or technique.
I built and varnished about a million sq ft of boats for 12 yrs. Then opened a cabinet shop which has evolved into an Architectual Millwork business. Anyone can build a cabinet, a door, or molding, it's the quality of the finish that sets the exemplary apart from the so-so. We used to say a good finisher could make a mediocre carpenter look great.
First thing is to buy the best (usually most expensive) natural bristle brush available. Can't recommend any as we've been spraying for 20 yrs.
Any of the varnishes mentioned above are good but one not mentioned was sold under the Ben Moore brand. It didn't have a uv filter.
I would skip the shellac as a primer or undercoat and go with a vinyl sealer. This is a very quick drying product that is a great filler and will lend some water-resistance. Don't use a good brush, it will require lacquer thinner as a solvent unless you throw the brushes away. Personally I don't do well with polys, one of my finishers does wonderfully with it though. I'd use a high gloss natural varnish, much harder without the fillers needed to dull it, then a satin, 60 to 80 sheen, for the finish coat.
The vinyl requires about a half hour to sand and the varnishes about 24 hrs.
Good luck.
Paul
tarnished is offline   Reply With Quote
Old 03-24-2013, 09:47 PM   #32
1963 19' Globetrotter
Orion , Illinois
I have been a professional furniture finisher/restorer for fifty years and all I can say is that you can get excellent results with any number of finishes and methods. Remember you are doing cabinets, not a boat ;so don't get hung up on the idea that because something is "marine" it will be the ultimate finish. I do not use any poly products in my work as I don't like a number of their qualities and they are hard to repair if the finish is damaged in the future. My suggestion is to buy a variety of materials in small amounts and experiment with them see what you like and what gives you the best result. No matter what you use some key points are - it has to be clean and properly sanded to start, sand between coats , keep things as dust free as possible , take your time. Good luck!
63air is offline   Reply With Quote
