Old 09-08-2015, 10:03 AM   #1
TMT
TMT's Avatar
1974 23' Safari
2005 22' Interstate
Jacksonville , Florida
Has anyone painted this trim?
This is a photo of the trim between the countertop and the doors below the sink. Has anyone ever painted this strip between the metal? Can you please share how you did, what you used, etc. Thanks.
Melaine Taylor
Life Is A Journey - Enjoy the Ride!
TMT is offline   Reply With Quote
Old 09-08-2015, 10:29 AM   #2
1974 Argosy 20
Kooskia , Idaho
That trim is easy to remove and replace. I would not paint it.
Two possible solutions:
1. Cut thin strips of countertop laminate (formica) and push it into the channel. However, this requires end access from one end or the other as the laminate is stiff.
2. Go to a shop which sells vertical venetian blinds and buy some slat material in a color/pattern/texture you like. Cut the slats down to the right width and simply bow them to slip into the slot you have. This is the technique I use most with these channels and it works very very well.
Old 09-08-2015, 10:37 AM   #3
cameront120's Avatar
1972 25' Tradewind
As idroba said, that piece will slide right out of the aluminum extrusion. You can then replace it with a piece of laminate (or any other flexible material) that better suits your tastes.
North Vancouver, BC
Old 09-08-2015, 11:13 AM   #4
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
agreed
Yes, take the oven out, 4 screws and the lp line disconnect, and it should slide out with some care. If you get it out in one nice piece I would LOVE to buy it from you (woodgrain insert that is) John
moparjohn is offline   Reply With Quote
Old 09-09-2015, 05:54 AM   #5
TMT
TMT's Avatar
1974 23' Safari
2005 22' Interstate
Seems like a lot of work for one piece of woodgrain insert. Think I may keep it!
Melaine Taylor
Anyone painted Zip Dee awning? VintageGypsy Awnings 4 04-27-2014 10:07 AM
Tambour trim and trim Big C General Repair Forum 6 08-14-2012 08:01 PM
The Argosy "beast" has been painted jjustice Clearcoat, Exterior Paint & Trim 22 05-24-2010 08:24 PM
Painted Trim on Classics Mobile1 Classic Motorhomes 3 11-15-2005 07:02 AM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
