Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 10-09-2009, 11:42 PM   #1
Cstar's Avatar
Profile:  2006 28' Safari SE
Columbus , Ohio
Images: 21
Granite Counter Tops
I have been considering adding granite counter tops to our '06 28SE. I am not concerned with weight issues only whether it is feasible from an installation and cost perspective.
I have a source to get granite left over from bigger installations that will be very cost effective. The counter tops in the 28 are really quite small when you consider the large cutouts for the sink and cooktop in the kitchen and the small footprint of the bath counter.
I am concerned with what is under the existing laminate. I have been told there is a plywood underlayment that would likely work as a base for the granite. I am concerned that the granite may be thicker than the OEM laminate thus requiring plumbing changes rather than just a remove and replace operation. I am also concened with what type adhesive to use to mount the granite. Obviously something flexible and able to withstand the movement and vibration of the trailer while being towed.
The factory is nearbye and I have visions of them removing the existing laminate and then taking it to have the granite shop use it as a template to shape the new granite tops. Returning the finished granite to the factory for the install.
Any thoughts, warnings or encouragement?
Corky
Cstar is offline   Reply With Quote
Old 10-10-2009, 01:40 AM   #2
4slice
4slice's Avatar
Profile:  1977 31' Sovereign
Prince George , British Columbia
Corky,
I think your plumbing changes would be minimal if you are only adding about 5/8 or 3/4 inch to the countertop height and thickness. The stove will be affected, which may require spacers on the bottom by the amount as the countertop thickness. You may want to have the countertop supplier take a look at the existing countertop while it is still in place--he can make a template from the top where it sits, and let you know if you are going to have any "challenges" at installation time. I used to sell kitchen cabinets many moons ago, so I had to measure up for countertops all the time. There are a dozen unexpected things that may need to be considered before ordering. Good luck--I still have the 1977 laminate (tired of hearing "it's so retro!"), so I've been dreaming of granite in my A/S as well!
4slice is offline   Reply With Quote
Old 10-10-2009, 02:35 AM   #3
Commercial Vendor
vinstream's Avatar
Profile:  1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
no...no....no! Ounces equal pounds.... If you do not understand this... You should.... No...no...no.... Granite! Never...!!!!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
vinstream is offline   Reply With Quote
Old 10-10-2009, 03:42 AM   #4
Power to the People !
Maryw164's Avatar
Profile:  1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
What about a product called "granitcrete":
Granicrete International, Inc. > Product<br/>Systems > Countertops
Or granite transformations:
Installation | Granite Counter Top Overlay | Granite Transformations
They are options that are light weight with the "look" of granite
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 10-10-2009, 07:04 AM   #5
Cantrell's Avatar
Profile:  1988 34' Limited
Mt. Pleasant , South Carolina
Granite, at 1 1/4 inches thick, weighs about 20 pounds per square foot.
It is also very weak at the points where you make cutouts and it sounds like you have plenty of those. The stress and vibration of rolling down the road will likely crack your countertops apart. At the very least, have the granite guys apply the mesh and epoxy to the underside to strenghthen it before installation.
Good luck.
Bill Cantrell
__________________________________________________
The aspects of things that are most important to us are hidden by their simplicity and familiarity.
Cantrell is offline   Reply With Quote
Old 10-10-2009, 11:14 AM   #6
Cstar's Avatar
Columbus , Ohio
Images: 21
Thanks for the responses.
Cantrell - I think you have the most compelling reasoning to avoid the granite. The cutouts will cause there to be more than one area where the width of the remaining counter top will be very narrow, only a few inches. That is a scary proposition when the thought of transporting the counter top before installation and flexing after installation is considered. I made a table with a granite top for the patio that measures 5' x 3' and was cautioned to beat the band about how to transport and carry it so it would not flex because of the possibility of it breaking.
Maryw164 - I checked both sites you mentioned. It appears the finished product is only about 1/8" thick. I don't see that holding up well to the flexing either.
vinstream - yes...yes...yes... weight is a factor. But believe it or not I prefer to add weight to my set up to allow the trailer to work the suspension of the tow vehicle a little more. F250 longbed diesel, it actually makes for a smoother ride for my application. From my calculations I will be adding less than 150 lbs.
4slice - I don't want my 'dream' to turn into a 'nightmare' so I will proceed cautiously. I may have to cosider other alternatives. I don't know whether something like Corian is lighter and or able to flex a little without breaking. But the laminate has to go at some point (so much for the ability get get a good deal on granite!). I have the mental image of 'cheap' for that look rather than 'retro'.
Corky
Old 10-10-2009, 11:26 AM   #7
CLOUDSPLITTER
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 52
Make sure they have been checked for Radon.
Like others, IMHO way to weighty.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 10-10-2009, 01:04 PM   #8
2airishuman's Avatar
Profile:
Originally Posted by Cstar View Post
... I don't know whether something like Corian is lighter and or able to flex a little without breaking...
this is what the a/s FACTORY has used for almost 20 years, so C is field tested with good results in streams...
the C is compatible in weight to laminates glued to glue soaked ply...
the C material a/s uses is thin, about 3/8s, maybe thinner.
it does flex, but can crack. (check the running gear or get rid of the counter top mounted anvil)
Corian Counter Top
and IF you are planning to have the work done AT the factory service center,
they obviously have experience with the material and construction and custom fitting...
a/s only offers 3 colors on new units but no doubt could order from the full C palate.
it's basically a fancy plastic but with the look of granite, but MUCH less weight and MUCH easier care...
here's a pic of my galley, followed by an unrelated thread with more shots...
http://www.airforums.com/forums/atta...4&d=1139375478
Sink Covers Revisited
some options/views on color choices...
corian color preferences and vinyl floor choices?
some general threads on the issue, with pics of white in use by a diy retrofitter...
Corian Counter Tops
Corian Countertops???
rkmoe's ivory C can be seen in his galley pics here....
http://www.airforums.com/photos/brow...page=24&sort=2
and the story of a member HERE who traded a brand new safari, partly because of the LESS than ideal glued laminated counters...
http://www.airforums.com/forums/247872-post43.html
(more pics in that thread about this..)
i've been very satisfied with the C.
easy to clean, minor scratches buff out quickly and once waxed again it looks as new.
major scratches can be buffed or filled and TRIVETS or protectors must be used for HOT stuff, because it can melt...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-10-2009, 11:26 AM   #9
Minno's Avatar
Lexington , Minnesota
Perhaps you should look at that new high definite (HD) laminate, by Wilsonart, that has the look of granite. I know, it's not granite. But, having seen it up close, it is very nice looking, and certainly a different look from "retro". Not to mention, very durable for a trailer.
Kay
Old 10-10-2009, 12:18 PM   #10
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet No for Many Reasons
All the issues about weight are certainly true. More weight inside the trailer would only load its axles, not help smooth out the ride of your F250. There is also the issue of side-to-side balance that is almost never discussed.
After searching for a source of solid surface material for a project, I found a local supplier that would sell me some. It is normally only sold to "trained" professional installers. The person the owner assigned to helping me with the order told me that she and her husband considered using it in their boat, but because of the weight and other issues, they chose laminate. So did I, and ended up buying elsewhere, since they didn't sell laminate.
The fragile nature of real stone, or masonry faux stone, makes them even less suitable for applications that move.
I ended up using the Wilsonart HD laminate (see: Wilsonart® HD® High Definition®) in the Deepstar Mineral 1817-35 (Deepstar Mineral 1817-35) pattern.
The results have been excellent! I used cabinet grade plywood instead of particle board, so the new tops are actually slightly lighter, not to mention much more durable. The new dinette top is here: http://airforums.com/photos/showimag...0&userid=17830, and the new credenza top is here: http://airforums.com/photos/showimag...0&userid=17830.
The credenza top was the reason for the new tops, to give me a place for the new 37" flat screen TV/Computer Monitor.
They are not real granite, but everyone who visits comments on them. I have been using these every day for over 2 years and they still look great. If I were to change anything, I would use an aircraft honeycomb panel instead of plywood to reduce the weight even further, but there is a very large cost to the aircraft panels.
Vaughan
A sixth sense (I lack the other five) tells me that I am in serious difficulties. Oscar Levant
vswingfield is online now   Reply With Quote
Old 10-10-2009, 03:31 PM   #11
4slice
4slice's Avatar
Despite the real concerns brought up regarding granite, it is feasible if done right. As far as weight goes, it depends on the total area to be covered--in my A/S, there are about eight square feet of top (after removing the sink and stove area). Most granite tops are actually 5/8 or 3/4 thick, with a doubler strip added to the front edge to make them look twice as thick. Eight sq ft at 20 lbs per foot is 160lbs of added weight. As long as you take that into consideration when loading your personal effects and water, you would be fine. Some people pack light, while others load up to the gills (I'm the sole user of my trailer, so I tend to pack light).
The other issue is flex, and having the top crack. It can crack at the weak points such as the corners of the cut-outs, or the middle of the strip that runs in front of the sink (as that is a point where one oftens puts hand pressure). The fix for that is to use control joints. The top is made in two to four pieces and fixed to the plywood base with caulking. The control joints are micro-beveled and a matching colored caulk (or clear silicone on dark granite) used to hide them. That way you have the flexibility needed without cracks, yet still have the look of a one-piece top. As an added bonus, a few smaller pieces can be salvaged from leftovers from a large kitchen job, and you may get them at "rock" bottom prices....
Old 10-28-2009, 05:31 PM   #12
Profile:  1976 31' Sovereign
Missouri City , Texas
The Corian type solid surface has worked well for me. I replaced the old counter top with a Corian type solid surface and installed an undermount sink. I have traveled over 4000 miles and no sign of any flex problem or cracking. Here is the link to the thread on this project. Towards the end is a pdf with pictures of the before, during and after project.
Don
New Solid Surface Countertops
adonh is offline   Reply With Quote
Old 10-28-2009, 06:21 PM   #13
tallytwo1994's Avatar
Profile:  Currently Looking...
tallahassee , Florida
Besides the excessive weight of the granite, I'd be concerned about the construction of the cabinet bases and whether or not they can support the granite.
tallytwo1994 is offline   Reply With Quote
Granite counter top paint adonh Cabinets, Counter Tops & Furnishings 2 10-10-2009 04:13 AM
63 tradewind counter tops source durans54 Cabinets, Counter Tops & Furnishings 6 03-01-2007 01:43 PM
Steel looking laminate Counter Tops? surferstyler Cabinets, Counter Tops & Furnishings 18 09-05-2006 09:47 PM
Corian Counter Tops Rod Pease Cabinets, Counter Tops & Furnishings 24 01-22-2005 06:35 AM
Corian Counter tops smily Cabinets, Counter Tops & Furnishings 4 11-27-2002 08:31 AM
