Old 04-11-2010, 06:05 AM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Gluing Foam
We would like to increase the thickness of our twin mattress. I would like to add a 3" dense piece of foam on top of the existing foam. Can they be glued together; if so, what type of adhesive should I use. Thanks!
TAC PA-5
Roadrunner is offline   Reply With Quote
Old 04-11-2010, 11:07 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Yes. You can use 3M FoamFast 74 (Orange) Spray Adhesive...you spray it on both surfaces and adhere (the "orange" means it's orange in color). You should be able to purchase it at any fabric store that sells foam (like Hancock's or Joann's). Suggest you use high-density foam.
TB & Greg and Abbey Schnauzer
#3954
Old 04-12-2010, 12:12 AM   #3
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
If you can't find 3M, I have used rubber cement that they sell at office supply, coat both sides and carefully join, no movement once in place. don't need complete coverage just a quarter inch has held edge connected 2 inch foam.
Memory foam ?? toastie Upholstery, Blinds, Walls & Interior Finishes 27 04-17-2010 12:16 PM
Memory foam for our new AS myoung Upholstery, Blinds, Walls & Interior Finishes 23 02-24-2009 03:39 PM
Foam skirts Darrell Root Winter Living 3 09-06-2006 12:25 AM
Best upholstery foam to use? kitchenclose Upholstery, Blinds, Walls & Interior Finishes 9 07-14-2006 07:16 PM
cushion foam airtim General Interior Topics 6 04-18-2006 05:53 PM
