Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 06-01-2007, 09:34 PM   #1
krikles's Avatar
Profile:  1965 17' Caravel
west hills , California
Gaucho measurements for 65 Caravel
Hoping someone out there could help me. I have a 65 Caravel - its in transit now and I'm hoping to place an order for fabric to slipcover the gauchos. Does anyone know the measurements? Would greatly appreciate it....
Thanks in advance...
krikles is offline   Reply With Quote
Old 06-01-2007, 10:57 PM   #2
Vallejo , California
It would depend if you have the original cushion arrangement. On mine the side gaucho measures 48 inches wide x 76 inches long when folded out into a bed. It is 2 cushions, but originally it would have been 3 cushions. The front on mine is about 42 inches wide by 72 inches long, in 3 cushions. Your should be about the same dimensions, unless a previous owner modified things. I have see modifications of width before, but not length.
I hope that helps a little....
good luck with your new Caravel, they are great trailers.
Stan Z is offline   Reply With Quote
Old 06-02-2007, 05:41 AM   #3
toastie's Avatar
1955 22' Safari
Michigan , The Great Lakes State
If you have the original foam, consider replacing it, we recovered our 65 Caravel using about 14 yds of material with new foam.............
toastie is offline   Reply With Quote
Old 06-02-2007, 05:44 AM   #4
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Welcome to the forums and congrats on your new purchase!
You might want to consider waiting for the trailer to arrive (though I know that is hard to do). When we had our upholstery and foam replaced in our Bambi II, we actually gave the upholsterer the original gauchos to work from. By doing this, he could more accurately cut the foam and sew the covers by using the existing cushions as a template.
Good luck with your project! We would love to see photos of your new trailer too!
WBCCI Region One
Attitude is the only difference between ordeal and adventure.
yukionna is offline   Reply With Quote
another caravel owner davidw 1966-68 Caravel 46 02-03-2005 06:53 PM
Restoration of our Airstreamer Caravel Hagen 1965 Caravel 2 11-10-2002 02:15 AM
leaking around front window of 1969 Caravel David Henderson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-27-2002 11:01 AM
Caravel windows susan martin 1966-68 Caravel 1 08-21-2002 08:43 AM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
