Old 06-15-2016, 07:09 PM   #1
outbackbob's Avatar
1999 25' Safari
Clarksburg , California
Galley countertop to wall molding
Hello all:
Where can I find the molding between the galley countertop to wall?
What is this molding called?
This is from a 1999 Safari 27ft trailer.
Thanks, Bob
ID:	264550   Click image for larger version
Regards, OutBackBob
outbackbob is offline   Reply With Quote
Old 06-15-2016, 07:29 PM   #2
san antonio , Texas
Countertop trim
That is either a T mold or L mode just take a small piece with you and go to a big box Hardware store that you prefer and they can help you with the right one should be about 10-15 dollars for 8 ft stick
Tom D
Tom D is offline   Reply With Quote
Old 06-15-2016, 11:39 PM   #3
outbackbob's Avatar
1999 25' Safari
Tom D
Thanks Tom, I found this molding at the Home Depot. The problem began as the cabinet rivets failed and the cabinet began to fall away from the wall. Not Kool, so before I make this repair the molding will be replaced.
ID:	264575   Click image for larger version
ID:	264577   Click image for larger version
Regards, OutBackBob
T-Molding (Tee Molding) Trouble and Solution! shane_franz Cabinets, Counter Tops & Furnishings 0 07-05-2013 12:09 PM
Why is my burner in galley separating from countertop? amm3824 General Repair Forum 2 05-07-2011 09:04 PM
Galley cabinet pulling away from wall shinybean Cabinets, Counter Tops & Furnishings 2 09-04-2010 06:57 PM
Mirror affixed to galley wall Hal&Arlene General Interior Topics 5 03-07-2008 01:11 PM
Luan wall molding lp pwrstrk Member Introductions 1 08-06-2007 02:33 PM
