Old 09-04-2010, 01:07 PM   #1
shinybean's Avatar
1964 22' Safari
1969 25' Tradewind
Greenville , South Carolina
Galley cabinet pulling away from wall
I have a 1964 22' Safari. On our last trip, we had a gas leak inside. After shutting off the gas at the tanks, I inspected the galley area. I noticed that the cabinet and countertop is starting to pull away from the wall. I assume this caused a leak in the stovetop gas supply lines. There is also a vent on the side of the cabinet at the bottom. it is bent like something put pressure on it from above and caused it to bow out. I will try and post pics in a bit.
I'm thinking that I'm going to need to remove at least the stove, and possibly the whole cabinet unit to brace everything back up, but I have no idea where to begin. Any thoughts????
1964 22' Safari
2003 Dodge Dakota Reg. Cab
shinybean is offline   Reply With Quote
Old 09-04-2010, 02:57 PM   #2
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
I have some rivets broken off the cabinets and some separation with the kitchen and galley cabinets and it seems to be from worn out axles. It was there when I got the trailer - The PO pulled the trailer with a beefed up 3/4 ton Blazer with no WDH hookup just a 2 1/8th inch ball on the WDH receiver. It seems he was trying to beat it to death. My 1/2 ton 2006 GMC is smoother but I cannot say I did not do some of the damage also. This was also confirmed with Inland RV from the pictures I posted. I am repairing the pieces now and plan on new axles in teh spring. Anyway, you might want to look at yours.
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 09-04-2010, 07:57 PM   #3
Vibration causes the pull away problem.
The 2 primary sources of vibration is unbalanced running gear and/or axles that have perhaps expired rubber rods.
Wall-to-wall carpet alternative mcneon Upholstery, Blinds, Walls & Interior Finishes 9 11-20-2008 02:41 PM
CCD galley cabinet modification Steve & Susan 2002 - 2005 International 3 10-04-2008 07:29 PM
Mirror affixed to galley wall Hal&Arlene General Interior Topics 5 03-07-2008 02:11 PM
Galley Puzzle Cat Cabinets, Counter Tops & Furnishings 9 10-07-2006 06:26 AM
Pulling out a partition wall in a 59 59toaster Cabinets, Counter Tops & Furnishings 4 02-23-2003 04:25 PM
