Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 03-03-2008, 06:42 AM   #1
evelitalian's Avatar
Profile:  1966 20' Globetrotter
hogansville , Georgia
Images: 14
futon size?
I have a 66gt,i was wondering what the max size futon i could put in there,without interfering w/fridge.hard to get a true measure considering the curved walls.thanks
evelitalian is offline   Reply With Quote
Old 03-03-2008, 10:07 AM   #2
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Where are you wanting to put the futon? In the front curved end right of the door or on the side beneath the windows across from the galley?
In our '64 GT, we have the gaucho across from the galley and it makes into a 54" wide (wider than the original 48") bed leaving about 8 or 9" to pass in front of the galley. You really can't open the fridge much though when the bed is down, maybe enough to squeeze out the cream for coffee in the morning.
The front area which is a dinette in ours, makes into a bed about 36" wide without impeding on the door. A futon could block a portion of the door when opened.
The trailer is about 7'-6" wide (side-to-side) most futons are not that long so you should be fine either way. I guess part of your answer lies in the design of your futon and where you intend to use it. I would think a "full" would work better than a "queen" mattress. A "King" is probably out of the question in a GT.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 03-03-2008, 11:38 AM   #3
Images: 14
futon
this is the futon,were going retro,with the black/white floor,cobalt blue countertops.the futon is 80"x54"fully extended.it comes with a 8"mattress,should i upgrade to the 10"? plan on putting it at the front,where the dinette should be.I want the largest bed i can get.never slept on a futon,are they comfortable?
Old 03-03-2008, 11:59 AM   #4
InsideOut's Avatar
1956 22' Safari
Images: 87
Thumbs up Looks nice ~
My only concern would be the depth of the futon in the "couch" position...the space in front of the door to the shell is pretty limited and I don't think you would want the arms or seat sticking out into the doorway all the time. If you can get so "out-to-out" dimensions before purchase that would help. Our GT which is a couple of years older and 1' shorter than yours has 36" in front of the door. I'm not certain what a 20' 1966 has...but I don't think it too much more maybe 4-6".
Comfort? That's kinda relative. I have a futon in one of my guest rooms at home...it's pretty comfy, but I know there are different qualities/construction of the materesses available. The key is in the mattress - lay on it to test them out in the store to see what feels better to you. Ours was the best available at the time...it's about 12 years old now, not used very much but it's still comfy. They do tend to get a crease at the fold from being in the seated position more than the bed position - but, that's to be expected IMO.
Good luck in deciding what's best for you ~ post pictures when you can.
Shari
Getting new futon mattress to bend into Gaucho wacnstac Upholstery, Blinds, Walls & Interior Finishes 1 04-26-2006 09:02 AM
Flexsteel or Futon (PICTURES)? bimi Upholstery, Blinds, Walls & Interior Finishes 15 04-10-2006 09:17 PM
using a futon mattress instead of cushions tinsltootsie Interior Restoration Forum 7 05-13-2004 09:01 PM
Futon,futon,whose got a futon?? COArgosy78 General Interior Topics 11 10-08-2003 08:47 AM
replacing front couch with futon gatorsharon General Interior Topics 15 08-02-2003 01:02 PM
