Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 07-09-2007, 05:43 PM   #1
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Originally Posted by rickastream
TV Antenna--it elevates but I couldn't get it to rotate. Handle included:
Hey, I could use that, how would I go about getting it? Thanks!!
It's a little fragile, from a packing standpoint, as in I can't crate it. I'll cardboard it up and we'll see if we can motivate UPS not to stomp on it. I'm guessing it's about 6 lbs and shipping will be on the order of $12. If you're agreeable, send address and phone via PM.
Zep
Current 6-word memoir: Airstreams and Kayaks, a perfect match.
www.mindseyephoto.com www.airstreamdoctor.com www.pygmykayaker.com
Zeppelinium is online now   Reply With Quote
Old 07-09-2007, 10:28 PM   #2
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
Zep,
Sent you a PM about the trim. Really appreciate your efforts to share these parts.
Thanks ....
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 07-17-2007, 10:48 AM   #3
1977 23' Safari
1975 31' Sovereign
What's left--7/16/07
Two sets of windows. First are the three lower "eyebrow" (what are these called?) windows out of the Sovereign. They include the three metal trim pieces. See note below regarding the "C" clip. These windows are flat. They didn't seem to leak, but the solar film inside is crazed.
Name:	IMG_7009 low windows-s.jpg
The other set are Vista Views, two from the Sovereign and one from the Overlander. These windows are curved. (The short one from the Overlander, as well as the two lower windows, will be available later this year.) As you can see, they are discolored. I can't tell if it's just the solar film, or maybe one of the layers is plexiglass and that's what has turned brown. One thing to note is that the construction of the older and newer Vista Views is different. The older window has a "C" clip that retains the inner plexiglass. This clip is relatively easy to remove so that the window can be cleaned/resealed. To open the newer windows, you have to drill out two small rivets on edge side (at the seams, one in the middle of each long side, that can be seen in the photo). The three "eyebrow" windows above also have this clip.
Name:	IMG_7010 vista views-s.jpg
ID:	41327Click image for larger version
Name:	IMG_7011 clip-s.jpg
I have the three rubber "gromets" that go around the skin cutout for the Vista Views, also included in offer (not pictured). They're in good shape.
Zep
Old 07-19-2007, 06:10 AM   #4
Ganglin's Avatar
Gahanna , Ohio
Images: 13
I just wanted to say KUDOS to Zep for this effort. I benefited from this generous action with something so simple as thin plastic wood veneer. Junk to some but gold to a vintage nut.
Stuff like this is what makes this Forum a great place.
Gary
Old 07-19-2007, 07:00 AM   #5
7xp
Profile:  1978 31' Excella 500
Santa Maria , California
Zep
I'm interested in the windows from the Sovereign. I will check size of my windows and get back to you. Thank you......"Mac"
7xp is offline   Reply With Quote
Old 07-19-2007, 09:29 AM   #6
gparker's Avatar
Profile:  1970 31' Sovereign
Denham Springs , Louisiana
Hi Zep, I am also in need of a window. The one I need is flat, and roughly 30x9. Looking to put it in a 1970 sovereign.
Greg
Greg, Ashley, Olivia, and Jane Ashley
AIR # 13681
gparker is offline   Reply With Quote
Old 08-14-2007, 01:26 PM   #7
1977 23' Safari
1975 31' Sovereign
Sink and countertop
Anyone need the sink/countertop from a mid-bath unit? This is 39-1/4" long and about 15-3/4" wide (width varies, as you can see from the photo). I have all the edge trim and support pieces, but none of the tape inserts for the trim (the strip that conceals the rivet heads in the trim pieces).
The only defect is that both rear corners have a small crack.
Zep
Name:	IMG_7451 sink and counter-s.jpg
Name:	IMG_7452 cracked corner-s.jpg
Old 08-16-2007, 12:18 PM   #8
Cos
Profile:  1973 21' Globetrotter
Middletown , Rhode Island
I would be interested in any tambors or cabinet pieces remaining. Thanks
Cos is offline   Reply With Quote
Old 09-05-2007, 02:49 AM   #9
ayresdream's Avatar
Profile:  1971 29' Ambassador
Merritt , British Columbia
I'm wondering if the clock and thermometer are still available?
Donald Ayres
ayresdream is offline   Reply With Quote
Old 09-05-2007, 06:29 AM   #10
SwampBillies's Avatar
Profile:  1972 31' Sovereign
1964 24' Tradewind
Plant City , Florida
Send a message via AIM to SwampBillies
exterior trim
I don't know if you are letting go any of the exterior trim, but if you are I need a piece. You can find a picture of the piece i need here
Never argue with an idiot. They will drag you down to their level, then beat you with experience.
Debbie & Lewis Adkins
WBCCI #15754 --- AIR #18873
1972 - 31' Sovereign International (Betty)
1964 - 24' Tradewind (Glory)
2002 Ford F250 Super Duty
SwampBillies is offline   Reply With Quote
Old 09-07-2007, 08:25 AM   #11
1977 23' Safari
1975 31' Sovereign
No, no exterior parts. I've had a few pieces of trim fall off, too, and I like the exterior to be as original as possible. I do get rid of a vent now and then, or maybe a TV antenna, but that's all. I'm contemplating converting the scare lights to some kind of down light, but that's in the future.
Zep
Old 09-07-2007, 09:56 AM   #12
1964 24' Tradewind
Zep
Oh well....Thanks for letting me know...I will keep looking.
Old 11-20-2007, 02:46 PM   #13
1977 23' Safari
1975 31' Sovereign
Closet and pantry doors
The 3 closet doors are all identical width, 20-5/8". Two of them need some corner screws to tighten up the metal edges, but are in good shape. The third is good for edges and maybe skin, only. It's missing the bottom edge piece.
The two pantry doors are in good shape, but also need some corner screws. They are 13" wide.
All five doors have the full length piano hinge.
Four of the latches are operable. If the doors don't get scarfed up as a whole unit, the latches are available. PM me.
I really don't want to pack and ship these. If you need a whole door, plan on picking it (them) up.
Name:	IMG_8221 doors-s.jpg
Zep
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 08:34 AM
1978 Sovereign Sag??? JLD General Repair Forum 2 11-17-2005 10:29 PM
Tiny fan to bedroom of Sovereign helps cool and warm the space Joan D'Andrea Cabinets, Counter Tops & Furnishings 2 11-02-2002 12:10 PM
85 Sovereign 25' j54mark 1985 Sovereign 7 10-30-2002 10:23 PM
Help with Ancient Sovereign patti 1956 Sovereign 2 06-06-2002 03:23 PM
