Old 03-25-2011, 07:19 AM   #15
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
Got it installed
Here is the finished project with the Aqua Boomerang. We got a little carried away and replaced the faucet also. Cabinet dude had some old leftover aluminum trim so we put that on as well. And while we were on a roll, did the bathroom too. Found a new stainless steel sink. Now we need to get rid of that ugly wall paper in bath.
Cabinet guy was more than $75. by about 5X with the trim and back splashes. He made new counter tops from plywood so he could screw in the trim.
ID:	125266   Click image for larger version
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 03-25-2011, 08:17 AM   #16
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
My formica job
I wanted to replace the original tops with formica ...something plain. I asked around and found rolls of formica abandoned in a lumber yard storage shop. I chose the red to fit the colors inside the Curtis already...(original was a white tile pattern.) 5$ for a 12 x 4 roll. A can of adhesive and a throw away brush.
Let me tell you, cutting formica without chipping is an ordeal. I found that going very slowly with a very fine tooth jig saw blade the best. GO SLOW.
Adhesive applied to both surfaces and let it dry completely. I used 1/2 dozen broom/mop handles laid across the plywood tops to align and keep separate the two pieces for the joining. You cannot even touch the pieces together for the alignment....they touch...they are done....stuck. I found that by cutting the formica a few inches larger than the top gave some lattitude to work with. Slid the handles out one at a time and had the good adhesion.
I used a router to now trim off the excess edges for final size.
A chipped formica edge is sharper than a scalpel.....I had it literally shave pieses off my hands as I worked with it and some chipped pieces.....be careful.
Name:	looking foreward.JPG
ID:	125268   Click image for larger version
Old 03-29-2011, 11:52 AM   #17
Arrowstream's Avatar
Columbia , South Carolina
I went to a Formica distributor today and they contacted the main warehouse (in Indiana?). Formica has discontinued the boomerang and virrvarr patterns, but there is still some left in supply.
6940-58 Skylark Boomerang 5 sheets 4x8, 21-5x8
6941-58 Coral Boomerang I got there last 2 sheets
6959-58 Aqua Boomerang 43-4x8, 23 5x?
6943-58 Virrvarr white 58+ sheets left
There's still some out there.
Arrowstream is offline   Reply With Quote
Old 04-25-2011, 12:01 PM   #18
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
We just remodeled our kitchen in our (non-mobile) home with the Aqua Boomerang Formica, we ordered 2 5 X 8 and 1 4 X 8 sheets from Lowes for less than $200...sadly it has been taken out of production and will only be available until their (Formica) stock is depleted...we are just lucky that we didn't wait another year to do the kitchen remod.
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 04-25-2011, 12:48 PM   #19
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Pics??? I'd love to see what it looks like up close. It's hard to see the detail in AirHeadsRus' pics. I'm thinking about using this color for my '58.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 04-25-2011, 02:33 PM   #20
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
You should be able to go to a countertop fabricator who uses P-lam (plastic laminate, Formica generic) and find some kind of groovy pattern, maybe even boomerang. There are a number of companies making p-lam and having something made shouldn't break the bank for a tiny Airstream kitchen.
Wilsonart, manufacturer of decorative surfacing materials and adhesives for countertops and work surfaces
Abet Inc.
Laminati USA
Nevamar HPL
and then there is this stuff, maybe not for countertops but beautiful and god-awful expensive, but the sell off cuts.
3form USA - Order Samples And More - Reclaim
Peter
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-25-2011, 03:10 PM   #21
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
We'll put some pics up once our kitchen is complete...picking up the metal trim next week.
Old 05-06-2011, 03:48 AM   #22
Here's a close-up of the aqua boomerang, Mike
Old 05-06-2011, 07:36 AM   #23
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Thanks, Arrowstream. That's beautiful.
1958 Overlander
4CU 1st VP
Old 05-15-2011, 10:58 AM   #24
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Well...after taking inventory from the home kitchen remodel, I decided to use up my leftover material and install the boomerang formica in the Argosy for the galley countertops and the folding dining table. Once complete I will post some pics...
Old 05-17-2011, 01:45 PM   #25
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Here's the new galley sink/stove countertop and backsplash. I ripped pieces of the formica to 1 1/8" to slide into the face trim as well.
ID:	130043   Click image for larger version
ID:	130045   Click image for larger version
Old 05-17-2011, 03:14 PM   #26
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
We had originally looked at the boomerang as well...but decided on the electric green from Lowes. Options abound!
ID:	130048   Click image for larger version
Roadrunner is offline   Reply With Quote
Old 05-21-2011, 01:24 PM   #27
I like the green too, but I wasn't brave enough to use it when I re-did our A/S counter tops, I used the blue instead (glass plastique). I used the boomerang in our 14' Shasta.
ID:	130331   Click image for larger version
Old 05-21-2011, 01:41 PM   #28
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Yet another reason to love Airforums.
I'm sitting on the back porch trying to figure out how to best machine the edges of the Formica kitchen counter top and up pops this thread. Thanks for the ideas, guys.
www.nesa.org
Air No. 6427
Formica source for table, etc Cristina1966 Upholstery, Blinds, Walls & Interior Finishes 6 10-15-2007 07:58 AM
'65 Safari Formica? Speckles? zoeb nj Cabinets, Counter Tops & Furnishings 4 09-08-2005 10:14 PM
New Formica Colors silver 67 Cabinets, Counter Tops & Furnishings 1 09-08-2005 05:23 AM
Cutting Formica COArgosy78 Cabinets, Counter Tops & Furnishings 31 09-21-2004 12:03 PM
Masonite or Formica - 1954 Flying Cloud? hiyosilver 1950-1955 Flying Cloud 3 07-05-2004 01:25 AM
