Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 11-11-2008, 07:20 AM   #1
mamos's Avatar
Profile:  Currently Looking...
Falmouth , Cornwall
Fixing overhead cabinets
Hi All
What is the recommended method for fixing overhead cabinets to the inside skin ?
mamos
mamos is offline   Reply With Quote
Old 11-11-2008, 08:14 AM   #2
Profile:  1975 Argosy 22
Charlottesville , Virginia
My Argosy manual recommends #8 sheet metal screws drilled with a #30 drill bit. I just removed my overheads and they were indeed screwed in not rivetted. I also had aluminum T molding mounting the cabinet (one inside edge was attached to the skin, the other to the inside cabinet wall with rivets). The cabinet should be light as Overlander would attest to.
Hope this helps.
Ken
uniquemicro is offline   Reply With Quote
73 sovereign international overhead cabinets kayaker41 Cabinets, Counter Tops & Furnishings 3 04-23-2007 12:01 PM
Worth fixing or not. chapparel Dollars & Cents 8 11-02-2006 10:31 AM
Fixing up the kitchen juel All Argosy Trailers 6 11-20-2005 03:19 PM
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 02:30 PM
310 Overhead cabinets jkleven Airstream Motorhome Forums 7 07-23-2002 01:08 PM
