Old 06-10-2010, 06:59 PM   #15
Dan Clayton's Avatar
1956 22' Flying Cloud
West Linn , Oregon
Images: 14
Here is some answers to everyones questions. I installed all of the wood over the metal walls. The wood is Birch, 1/8 inch with 5 coats of exterior water base clear which was sprayed on. The clear coat is made by General. The trim pieces that cover the seems was easy to put on except for the two rear pieces that have a dual compond curve. Those two pieces required steaming to get them to bend without breaking. Once they cooled they kept there shape. The fridge is a Dometic # RM2351. Little smaller then I would like to have put in, but I wanted to keep it under the counter, rather then put in on the other side which is were the closets are located. Plus I have a surround sound system, and a wet jacket hanging area with a drain pan going into that area, remember I live in Oregon!
The last A.S I did was orginal design lay out, just refind. This time I layed out this trailer the way I really wanted it. It has some of the look of old with a mix of new and safety.
Dan Clayton is offline   Reply With Quote
Old 06-10-2010, 07:11 PM   #16
OO , OO
Send a message via Skype™ to cruiser54
Thank you for the explanation of your work!
Impressive...
Greetings from Switzerland
Werner
cruiser54 is offline   Reply With Quote
Old 06-11-2010, 11:03 AM   #17
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
1/8 inch Birch? Is that 1/8" Birch plywood or a Birch veneer? Can I ask where you got it? It looks gorgeous!
Chris
Old 06-11-2010, 05:41 PM   #18
West Linn , Oregon
Images: 14
It's Birch plywood. Its made of about four layers of a cheaper white wood with a veneer covering. You should be able to get it at any large fine wood seller or mill. We happen to have many right here in my area.
Old 06-12-2010, 01:32 PM   #19
Minno's Avatar
1972 31' Sovereign
Thanks Dan.
1956 SOTR - YES!!! Got it! Sugarfoot 1955 - 1959 Sovereign 155 10-02-2012 07:53 PM
1956 28 ft? Rhonda 1954 - 1959 Overlander 408 07-31-2011 09:25 PM
1956 Sovereign...help! mjmcwhorte 1955 - 1959 Sovereign 2 09-25-2005 04:50 PM
1956 ??? Over59 Our Community 6 09-20-2004 07:52 PM
