Old 04-23-2015, 08:39 AM   #15
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
My skills are pretty basic. If I can do it, so can you.
I have a good source for the flat bar trim. It is very flexible and easy to line up with panel seams. Once it is cut and drilled, I attached it to the end cap with #8 x 1/2" sheet metal screws spaced every 3-4". Then cut posterboard templates for each "pie piece" and mark the screws heads with a pen and cut the template to fit. Then tape to the birch ply and cut panel with a jigsaw. Sand, stain/varnish, then removed one trim strip, fit up panel and reattach trim. Repeat 12 times :-)
BambiTex is offline   Reply With Quote
Old 04-23-2015, 09:54 AM   #16
ericpeltier's Avatar
Superior , Colorado
Originally Posted by BambiTex View Post
These are 1/8" baltic birch ply panels trimmed with 1" x 1/16" aluminum flat bar. Time consuming but very happy with the results so far.
BambiTex,
Is the only attachment for your system the screws? Or did you use a little adhesive on the backs of the ply, too?
Eric
ericpeltier is offline   Reply With Quote
Old 04-23-2015, 09:56 AM   #17
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
No need for adhesive. Once you bend them into place, they stay put on their own.
Old 04-23-2015, 04:14 PM   #18
Mixter's Avatar
1976 27' Overlander
Thats a great look! Keep the pics coming!
Mixter is offline   Reply With Quote
Old 04-27-2015, 06:38 AM   #19
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Panels
OK. Here is the finished product.
ID:	237161   Click image for larger version
Old 04-27-2015, 06:46 AM   #20
Mixter's Avatar
1976 27' Overlander
Very Nice!
Is this the end of my end caps? unit13 Upholstery, Blinds, Walls & Interior Finishes 9 01-02-2017 10:42 AM
plastic end caps for horizontal blinds bpcaudill Upholstery, Blinds, Walls & Interior Finishes 6 09-26-2006 07:44 PM
Stripping the Interior End Caps--Am I Nuts? ironfem200 General Interior Topics 2 01-29-2006 04:07 PM
What kind of interior paint 1971 Overlander/End caps dingy riverdreamer Upholstery, Blinds, Walls & Interior Finishes 5 05-24-2004 09:36 AM
Styrene end caps for the aluminium bed extrusions chasgould Upholstery, Blinds, Walls & Interior Finishes 0 05-23-2004 04:23 PM
