Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 02-19-2007, 06:25 PM   #1
Cos
Profile:  1973 21' Globetrotter
Middletown , Rhode Island
Early/Mid '70s Cabinet Renovate Approach
I have been trying to decide between replacing all the original fake woodwork in my '73 GT or keeping and repairing the simulated walnut. Has anyone taken the approach of reusing all the original cabinet aluminum pieces but replacing the the fake wood with a real wood (like a birch plywood)? Any pictures or links would be appreciated.
Cos is offline   Reply With Quote
Old 02-19-2007, 06:28 PM   #2
muddy_hollow's Avatar
Profile:  1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
cabinets
I've got a slightly older model than yours, but my interior was shot due to water damage. I chose to rebuild/mod the cabinets that were not worth saving and then using a PSA veneer on the cabinets that were worth re-using.
I'm keeping a blog of my handywork.
D
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 02-19-2007, 07:16 PM   #3
Profile:  1973 23' Safari
Maryville , Tennessee
Images: 13
I have a 73 Safari that we were contemplating the same thing. I ended up gutting it in December after our first camping trip in it as I didn't get along with the tambour doors very well. I then hired someone to do the cabinet work but we ended up going all birch and got rid of the plastic/formica. We mostly used the existing cabinets for templates. Good luck!
kneal is offline   Reply With Quote
Old 04-04-2007, 09:07 PM   #4
dmroot's Avatar
Profile:  1971 23' Safari
Portland , Oregon
This post is a little old, but am responding...a previous owner (at least one or two previous owners ago) of our new 71 Safari did what you are suggesting: Birch doors with existing walnut laminate sides, etc. I am wanting to restore it back to the original laminate tambors for visual consistency. We are exploring some links that other forum members sent, salvage options and have a classified "wanted" post and hope to get to work with the restoration soon.
Here is a picture of how it looks now, note the contrast:
dmroot is offline   Reply With Quote
Old 04-04-2007, 09:12 PM   #5
vajeep's Avatar
Profile:  1976 27' Overlander
Copper Hill , Virginia
Images: 49
Total re-do. The wood on our 1976 was shot...
Here is the after galley photo.
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
WBCCI# 7627 / VAC
Air #2798
vajeep is offline   Reply With Quote
Old 04-06-2007, 06:04 AM   #6
Streamin 65's Avatar
Profile:  1965 26' Overlander
Marysville , Ohio
Images: 14
Why not just replace the walnut lam with real walnut? If you have some woodworking tools, the cabinets are pretty easy to construct, especially if you can use the old as a template. If your having it done, labor should be the same for either walnut or birch. The only variable is material cost and if you'd just rather have a lighter wood. Around here, a 4x8 sheet of good quality walnut plywood is about $60 for 1/4" and a sheet of good quality birch is $40 or so. Home Depot has imported 1/4" birch sheets, but the quality can vary for $20 or so. I'd dare guess the cost difference from using birch to walnut for your rig would be $300 at most.... Just a thought. --dave
Streamin 65 is offline   Reply With Quote
Old 04-06-2007, 06:08 AM   #7
1956 22' Caravanner
Very nice
Very nice. You should be happy with your handy work. Looks pro!
Doug
Sliding Cabinet Hardware LKappenman Cabinets, Counter Tops & Furnishings 5 10-20-2002 04:53 PM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 08:34 AM
Cabinet door latches 53flyingcloud Cabinets, Counter Tops & Furnishings 3 07-08-2002 03:28 PM
Door and cabinet knobs jcanavera 2001 Safari 0 07-07-2002 10:19 PM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 07:22 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
