Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 02-04-2004, 11:57 AM   #1
Cedars's Avatar
Profile:  1983 31' Excella
Waterloo , Iowa
doors won't roll up all the way
Two or three of the tambour doors won't roll up all the way, another one won't stay up!
I seem to remember a thread detailing how to adjust and lube this kind of door. Just can't find it right now!
So. Any suggestions on lubing, adjusting?
Elizabeth in Iowa
The carpeting is gone! The carpeting is gone! Long live the cork floor!
Cedars is offline   Reply With Quote
Old 02-04-2004, 12:12 PM   #2
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 231
"Tambour"
Elizabeth:
Use the Forum search engine (upper right hand button), and enter tambour.
There's a bunch of threads that deal with your question.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 02-04-2004, 12:12 PM   #3
Still Working
smily's Avatar
Profile:  North Charleston , South Carolina
Search "Tambour Doors"
There are many tips but they are simply that.
What happens is the rigidity of the door weakens over the years and the tambour will not slide in a straight line through the track. The small "slats" tend to try to fold and it cause the door to become wavy, rubbing on each side and binding in the track.
You can try to remove the door and trim the cloth from the rear of the door. Trim it from the edges that slide in the track. only problem with this practice is that the slats are made of pressed board. they will dampen or become soft and deteriorate.
Also, there is probably a lot of dust in the track from use. If you can get all of the dust out of the center of the scroll, that will help.
You will learn to teach everyone using the doors to be careful and maybe assist the door opening by using two hands. One near door handle and one in the rear of the door to help rigidity.
Its an Airstream thing.
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 02-04-2004, 12:31 PM   #4
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
I don't have this issue with this coach, but I have some friends that did have this type of issue. They used birthday candles to fix the binding. Open the door all the way, clean the track of dust and debris. Take a B-bay candle and using the flat end rub it in the groove of the track on both sides. Then open and close the door a few times. You may need to do it more than once to get them slipping. The wax will not cause the material to swell up like a liquid lube will, and should reduce the binding that is causing the problems that you are experiencing.
Good luck!
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
