Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 11-16-2004, 04:10 PM   #1
Profile:  Lansing , Michigan
Doing the countertop lean
My countertop in my 76 MH seem to be leaning into the back corner. How difficult is it to rise this back to level. Is is a matter of removing the oven or would you go from under the oven? Thought this was normal until I turned around when I was driving and noticed that the countertop was shaking and shimmering. Had to bring this burning question to the masses. Any help would be appreciated Thanks a bunch!!!!!!!!
Tom
tandemfish is offline   Reply With Quote
Old 11-16-2004, 06:19 PM   #2
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Tom,
I have replaced 2 counter tops on both my 76 and my 78 MH. The base is made of plywood, but the back-splash is particle board. The back edge of the counter is resting on/screwed to a large L shaped piece of aluminum that is screwed to the wall. The stove and its weight, resting near the rear wheels tends to walk the screws out of the wall. They are just in the inside sheeting. There should also be screws that go through the end wall next to the stove and into the edge of the wood substrate of the counter top.
In order to get to the ones behind the stove you will need to be VERY limber, or you need to remove the stove, and cut access holes in the metal heat shield that the stove sits in. The heat shield is installed before the counter is placed, bit somehow they get the screws in there??
If you are going to the bother of removing the stove, and getting access it is not that much harder to remove the counter top completely and make a new one. SAVE the edging that is on the original if possible. The aluminum band comes in handy to maintain a thin built up edge on the new counter top. A new sink and faucet and you are set!
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
OSB for countertop base? TomW Cabinets, Counter Tops & Furnishings 4 05-25-2004 03:08 PM
The lean... SCBrat Axles 5 11-24-2003 12:11 PM
Airstream Lean 72 Excella500 Axles 8 11-12-2003 08:21 PM
aluminum composite countertop repair? Janet Cabinets, Counter Tops & Furnishings 1 09-30-2003 10:38 AM
New Countertop smily Cabinets, Counter Tops & Furnishings 38 07-01-2003 07:16 AM
