Old 04-05-2013, 06:34 PM   #1
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
Hillpoint , Wisconsin
Does anyone have a source for true 1/4 birch plywood?
I need some 1/4 Birch plywood (6.35mm ) for repairs to my trailer and all I can find is what they call 1/4 which is only 5.2 MM. Does anyone make a true 1/4 birch plywood any more.
Thanks Steve
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
and a partridge in a pear tree
Sprouty is offline   Reply With Quote
Old 04-05-2013, 07:11 PM   #2
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
I'd suggest trying M.L. Condon Company Inc..
if they don't have it, they are likely to be able to tell you where you can find it.
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 04-05-2013, 07:26 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
I'd picked up some "1/4 inch" birch cabinet-back ply in Nordeast Minneapolis last month at Youngblood cabinetmakers' wholesale/retail lumber yard. Went down & measured it just now -- it's maybe 5.5mm or just shy. It has one a one-ply solid core -- core feels soft -- poplar?
But true -- nothing like a quarter inch.
5 meter Langford Nahanni
Old 04-10-2013, 08:39 PM   #4
Brand New Owner
dboatguy's Avatar
2013 30' Flying Cloud
Holland , Michigan
plywood
Check out this site.
I do a bit of woodworking and they have about everything. I notice some 6 nil birch under Russian birch and the marine listing. I am looking for the Melanie coated for the insides of the cabinets as well
Hardwood Lumber, Marine Plywood & Veneer Plywood Sheet | L.L. Johnson's Workbench
dboatguy is offline   Reply With Quote
Old 04-10-2013, 08:54 PM   #5
Sprouty's Avatar
1972 23' Safari
1956 16' Bubble
1947 22' Liner
I found some but it was a type of composit center and did not think it would hold up well. I am just going to use 1/2" plywood which is not really 1/2 but between 1/2 and 1/4.
2 Liners
2 Safaris
2 Flying Clouds
1 Bubble
Old 04-11-2013, 02:45 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Here is a source for pretty good material:
Plywood from Aircraft Spruce
Old 04-20-2013, 07:55 AM   #7
1976 25' Tradewind
clarkson , Nebraska
go to aitwood.com. I bought a lot of wood for building a couple of airplanes here. GREAT wood at GREAT prices. I believe if memory serves me right you can get it in 60 inch square pieces also. good luck
Tim
tim c is offline   Reply With Quote
Wing window gasket source... daved20319 Windows & Screens 5 07-05-2012 02:23 PM
2 layers of plywood? P&K Repairing/Replacing Floor &/or Frame 20 08-14-2011 08:15 AM
Removing 1" plywood under fresh tank bennyg Belly Pans & Banana Wraps 0 06-12-2011 02:50 PM
Aluminum Trim for Plywood Walls Motochi Upholstery, Blinds, Walls & Interior Finishes 7 02-06-2011 09:33 AM
Need new LP heat source for short bursts of winter use pyrenees Winter Living 12 01-04-2011 08:41 PM
