Old 01-03-2015, 05:36 PM   #1
Templeton , California
Angry Diabolical screws
I am attempting to restore my 24' a Boles Aero. The towel rack and paper towel rack are secured by six standard screws (not Phillips). They are tight but cannot be made tighter nor can either of them be taken out the racks are rock solid and the screws are tight but turn (both directions). There is no way to reach them from behind without destroying the cabinet. Any thoughts on this?
Chippewa is offline   Reply With Quote
Old 01-03-2015, 05:52 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Try inserting the edge of a putty knife or other very thin piece of metal under the edge of the screw head and apply outward pressure as you turn the screw with a good screwdriver. Many times a screw will start to back out if there is pressure on it like that. If that fails I would break out the Dremel tool with a cutoff wheel. With the screw heads off and the rack out of the way you can grip the end of the cutoff screw with vice-grips and it should unscrew as you pull outward and unscrew at the same time.
good luck
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
68 TWind is online now   Reply With Quote
Old 01-03-2015, 06:01 PM   #3
Chasmorgan's Avatar
1999 23' Safari
I use a Grabit set as a drill/extractor. Clean and easy and less than $20.00.
Charlie M
TAC TX-6
Chasmorgan is offline   Reply With Quote
Old 01-03-2015, 07:01 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Best thing for that job is screw pliers . Engineer PZ-58 Screw Pliers GT - - Amazon.com
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 01-04-2015, 08:04 AM   #5
Thanks for the help..at this point, I'm dragging out the Dremel and saving the neat racks...this is a great forum!
Old 01-04-2015, 08:29 AM   #6
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
If the screw turns in both directions none of these grip or retract suggestions will get it out. The dremel will get you a bit further.....Unless you get a small amount of "pull" pressure on it and then try to re-engage the threads on the aluminum thin panel.
Rivets or screws? TBKP's Overlander Interior Restoration Forum 3 07-25-2003 12:47 PM
Blobs of silicone on screws? Kistler Our Community 9 06-24-2003 08:06 AM
Rusty screws in side windows (galvanized) Orland Dewey Airstream Motorhome Forums 4 06-17-2003 08:42 PM
Screws... Chuck Ribs, Skins & Rivets 1 10-21-2002 08:22 AM
Clutch head screws Zed2 Windows & Screens 4 08-23-2002 05:16 PM
