Old 02-25-2014, 09:35 AM   #1
1965 24' Tradewind
Renton , Washington
delaminating cabinet veneer
Hello Everybody,
I'm a new Airstreamer and I have a 65 Tradewind. I bought it in San francisco and towed it to Seattle. The humidity here is ruining my cabinets! I could replace the plywood doors but I'm afraid it will just happen again. I do have a dehumidifier and the dry-z-air in the trailer but the wood is still curling up. I was thinking about maybe solid wood doors so there is no veneer to peel. I have to store it out doors. Does anyone have a good solution for this?
Thank you!
~Wildman~
wildman is offline   Reply With Quote
Old 02-25-2014, 10:03 AM   #2
1973 25' Tradewind
Beautiful , Oregon
If the humidity is so bad to cause problems with the veneer I suspect you could have a lot of movement in solid wood cabinets. Including possible cupping and warping. You probably should go with a panel and frame door. It would still have ply for the panel but the edges would be captured.
Good Luck
Tony
Tony S is offline   Reply With Quote
Old 02-25-2014, 10:24 AM   #3
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
Like Tony says solid is probably going in the wrong direction to combat humidity, plywood is more stable by design. How about trying some interior cabinet grade plywood from a marine supply store? A boat probably has similar moisture concerns, I'd drop a line to someone like WorldPanel as they seem extremely knowledgeable and helpful.
truckasaurus is offline   Reply With Quote
Old 02-25-2014, 11:11 AM   #4
1965 24' Tradewind
Renton , Washington
Thanks great idea
Old 02-25-2014, 12:05 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I have only had that level of delamination when I had excessive moisture, from leaks when my trailer wasn't under cover. I keep a Dry-Z-Air in there, along with a heater running on low, and it's under cover now, and haven't experienced any delamination this winter. The stuff that did delaminate I was able to reglue the part that lifted up and preserve the vintage cabinets.
Stephanie
Old 02-26-2014, 11:30 AM   #6
1973 25' Tradewind
Beautiful , Oregon
If you do need Marine Plywood Crosscut Hardwoods will treat you right. You can also go folks out of Port Townsend, forget name.
You probably would want Okoume. It is a Mahogany like color. More like laun but it is closer than alternative of fir or meranti.
Like Stefrobrts said best to deal with the moisture problem
Good luck
Tony
Old 05-29-2014, 09:46 PM   #7
1970 27' Overlander
1970 21' Globetrotter
Hamilton , Montana
If the wood is moving you may have finish that is worn off. You could try a clear coat but paint all side of the wood if posible as you want the moisture to come and go evenly or you will get warp.
gdod25 is offline   Reply With Quote
56 Bubble Parts, Need overhead cabinet elfirebob Airstream Classifieds 0 02-04-2014 12:09 PM
removing the heater and cabinet from a 70 Overlander rayandre Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-08-2011 08:17 PM
Will standard HD cabinet latches work? adwriter73 Cabinets, Counter Tops & Furnishings 0 05-14-2011 01:09 PM
Need to see pics of med cabinet rverforlife General Interior Topics 1 05-10-2011 12:05 PM
nt-22A cabinet tracker Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-13-2011 09:54 AM
