11-30-2014, 07:58 PM
1975 29' Ambassador
Fort Wayne
, Indiana
Cracked End Cap
We are working in a 1977 Airstream. The end cap has a few cracks. We do not want to take it down to replace it.
Can someone tell me of a material that will fix the cracks that can be sanded and painted?
12-01-2014, 08:28 AM
1973 21' Globetrotter
Houston
It is likely made of ABS. I had some small cracks in mine as well and tried to repair it using the ABS cement you would use in a plumbing project, but it didn't stick so well. I ended up using a conventional epoxy, and so far it is holding. That being said, my cracks were very short, and are immobilized by riveting the end cap in place. You might post a picture of your cracks so we know what you are up against.
good luck!
12-01-2014, 09:00 AM
1986 31' Sovereign
Miami
I used my hot glue gun and it worked pretty well on the thin cracks but not on the larger ones.
Mike
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
12-01-2014, 09:32 AM
Princeton
, New Jersey
I had cracks in the corner of the overhead cabinet in the rear cap. If you can remove the cabinet and get to the rear of the cap you can fiberglass across the crack and that will hold. I used 2 layers of 4 oz. glass.
The crack was about 3 in. long starting at the corner of the cabinet.
2004 Excursion 4x4
12-18-2014, 10:06 AM
1975 25' Tradewind
Navarre
I have two cracks in my end cap. The other is a mirror image of this one. Both cracked right where a rivet holds it to the ceiling. I am about to start painting the end cap today. Any suggestion for a particular adhesive?
12-18-2014, 11:39 AM
1964 26' Overlander
Richmond
, Virginia
I would suggest drilling a small hole at the end point of the crack to prevent it from going any further. Then, I used a some cement that is supposed to be universal - ABS, CPVC, and PVC. Rub it in to see if it starts to melt the plastic, then you know it will work. I think I had mine off, so I shaved some plastic from a part you couldn't see, made shavings, disolved them, then painted it back on, and then sanded.
rob
12-18-2014, 01:11 PM
1981 31' Excella II
New Market
, Alabama
Consider a trim piece that is bow shaped that just covers up that seam. I have the beginning of that sort of crack. The only thing that will stop it from cracking would be to put some fiberglass cloth and resin on it and sand it down flush then paint it. It will keep cracking unless there is something there like fiberglass to reinforce it. The crack started in a rivet hole.
Perry
01-08-2015, 08:37 AM
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
Methylene chloride... I did a thread on repairing my old yellowed fridge that gives info on using it... here is the thread
http://www.airforums.com/forums/showthread.php?t=125067
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
End cap replacment
till |
Exterior Restoration Forum |
6 |
12-31-2004 04:30 PM |
Interior End Cap
mjohnson63 |
General Interior Topics |
4 |
04-07-2004 05:34 PM |
End cap repair
CO_Don |
2 |
08-04-2003 03:28 PM |
Plastic cabinet end cap
wcdelorme |
Cabinets, Counter Tops & Furnishings |
0 |
05-11-2003 10:12 AM |
front, end cap
George |
Ribs, Skins & Rivets |
9 |
04-07-2003 04:48 PM |
