Old 11-22-2014, 06:08 PM   #1
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Crack in our kitchen countertop
This will be something we have AS address under warranty, but I thought I'd put it out there to see how folks who know what they are doing have successfully fixed this kind of issue.
So, we just found this crack in the Corian kitchen countertop in our 2014 International Signature 27FB. Is this something others have seen and fixed?
Name:	ImageUploadedByAirstream Forums1416704919.431453.jpg
Rocinante is our 2014 International Signature 27FB
Old 11-22-2014, 08:18 PM   #2
dave_oleary's Avatar
2013 25' FB International
Gig Harbor , Washington
With a new AS, I would go back to the dealer to have this covered by warranty. It most likely happened while towing it and they should replace it for you.
dave_oleary is offline   Reply With Quote
Old 11-22-2014, 09:25 PM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
It seems like there ought to be something flexible between the inflexible Corian top and the flexible cabinet attached to the flexible Airstream structure. Maybe a very thick bead of soft sealant/adhesive.
Doug and Cheryl
Old 11-22-2014, 10:06 PM   #4
Rivet Slave
Rocinante's Avatar
Thanks. We'll definitely go back to the dealer for warranty service on this, possibly insisting they replace the entire countertop, as I don't want a cracked countertop with a silicon bead on it. That just seems a recipe for unhappiness. I just wondered whether other people have had this happen and if so, what typically fixes it once and for all, aside from a complete replacement.
Old 11-22-2014, 10:23 PM   #5
dkottum's Avatar
This was really not meant as a fix to repair the present crack but a possible way to mount the new replacement. If it broke once and they just put a on new one same as before it'll probably crack again. Something caused it to crack.
Doug and Cheryl
Old 11-22-2014, 10:24 PM   #6
Rivet Slave
Rocinante's Avatar
Right you are - some kind of flexibility in the mounting that allows for the inevitable flexing during travel seems well-advised.
Old 11-23-2014, 12:35 PM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Or a high spot under the edge that cracked off.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
J. Morgan is online now   Reply With Quote
Old 11-23-2014, 01:10 PM   #8
Rivet Slave
Rocinante's Avatar
Thanks for that suggestion. I'll ask them to check for this and level off any high spots before making the replacement.
I've heard that Corian can be repaired in ways that make the original injury invisible. Here's one quick search result that says cracks can be repaired, though I don't want a repaired crack showing - it would have to be blended in somehow. http://homeguides.sfgate.com/repair-...ops-30237.html
So, I'll ask them to replace the countertop under warranty, ensure a level plane across all the cabinet tops, and consider whether they should be putting something between the counter and the cabinets that would help absorb flex instead of transferring it to the counter and introducing another crack.
While we're at it, we'll have them take a look at the outside light above the door, which once again requires a good slap on the fixture to get it working after I turn it on. That connection must have come loose again.
Old 11-23-2014, 01:16 PM   #9
KatieMacSC
katherynhart's Avatar
1975 31' Sovereign
Morganton , katherynhartzell
Talking to a local granite installer, he has replaced RV countertops. He says be sure you have a flex gap between the front of the cabinet and the rolled edge. This looks like the cabinet may have been flush with the under edge of the countertop. He also leaves flex space on all wall sides that will be covered by backsplash, then shims up the backsplash for space and finishes with flexible caulk.
katherynhart is offline   Reply With Quote
Old 11-23-2014, 01:51 PM   #10
Rivet Slave
Rocinante's Avatar
Ah, thanks for that idea, much appreciated. I just sent email with photos and suggestions about possible causes to my dealer to start the chat about fixing this under warranty. We'll see what develops. They've been really good thus far about warranty work, so I'm confident we'll get this resolved as well.
Old 12-02-2014, 07:52 PM   #11
Rivet Slave
Rocinante's Avatar
So, Airstream says they want to repair the counter vs. replacing it. If they repair the cause and then repair the crack so that it cannot be seen, I'd be willing to let them do that. Otherwise, I'm going to press them hard for a replacement.
Old 12-02-2014, 08:40 PM   #12
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
If they can fix it well in place I would be inclined to think this is the best solution.
The idea is that they will not need to take so much apart. As a rule I think that the less factory stuff that needs to come apart the better.
Old 12-02-2014, 09:22 PM   #13
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Is that the crack continuing on the gray surface next to the ivory counter top?
I'd be interested in their repair process. If they don't remove the top, how are they going to determine why it cracked? If there is a high spot on the front edge or corner and they patch the crack it will just crack again. If they are going to remove the top, why not replace it?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 12-02-2014, 11:36 PM   #14
Rivet Slave
Rocinante's Avatar
Hey, John, let's hope you're right, though I'm concerned that whatever caused the crack will continue to stress / damage the counter after they fix the crack.
Still, I'm willing to let them give the crack-fix a shot, for the same reason - the less they tear apart, the better, as long as they can figure out what broke it and eliminate that cause.
Al, I will also be interested to know how they're going to fix it.
Oh, and the crack does not continue into the gray surface - that's actually the aluminum wall, and it's reflecting the image of the crack.
New Workstation/Countertop in our Serenity Suzzeee Cabinets, Counter Tops & Furnishings 8 08-19-2013 01:15 AM
Chicago Crack .... our summer souvenir bjond Ribs, Skins & Rivets 12 08-29-2009 07:05 PM
Countertop edging Jenturnr 1984 - 1989 Sovereign 5 05-20-2004 08:34 AM
aluminum composite countertop repair? Janet H Cabinets, Counter Tops & Furnishings 1 09-30-2003 09:38 AM
New Countertop smily Cabinets, Counter Tops & Furnishings 38 07-01-2003 06:16 AM
