Old 07-29-2015, 07:11 PM   #1
submariner's Avatar
1948 22' Liner
1989 34' Limited
long beach , Mississippi
Countertop Choices
Im looking to replace all counters in my 89 34ft Limited. I want to find something that looks good and fits to a western / texas style , but also does not brake the bank. Any suggestions? corian vs laminate vs engineered stone ? thoughts?
thanks
Stefan
Resurrecting one Airstream at the time..
maybe one day i save them all
submariner is offline   Reply With Quote
Old 07-29-2015, 10:05 PM   #2
Can of beans's Avatar
1972 31' Sovereign
Silverton , Oregon
Flamed plywood with edge trim coated in bar top epoxy resin. Sounds Texas/Western to me.
Or nailed down zinc fun.
Can of beans is offline   Reply With Quote
Old 07-29-2015, 10:37 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
You could use plywood then hammer flat a bunch of aluminum beer cans.. Texas beer cans, of course... then coat with the bar epoxy..
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-29-2015, 10:50 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Another 'option'.... get some high quality stainless steel, then 'dress' it with an automotive sanding disc... it make really bold 'swirls'... then you can coat with the 'bar coating'....
Or, how about getting some old barn wood, glue to the plywood, then coat... http://www.old-barn-wood.com
Channing
WBCCI# 30676
Old 07-29-2015, 11:19 PM   #5
1986 31' Sovereign
Miami , Florida
We used Marmoleum flooring. Looks great, cleans up with a damp rag. Lots of styles/colors.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 07-30-2015, 06:16 AM   #6
submariner's Avatar
1948 22' Liner
1989 34' Limited
Thanks guys for the tips so far. Whenever I replace the counters I actually plan on matching the bathroom , bedroom , dinette and living room table .. That's why I thought of manufactured stone , solid surface or a good laminate . The easy part on laminate would be , that I can overlay the existing laminate .. But I still think laminate does not look as good as solid surface or stone . I do like the idea of marmoleum and would like to see a picture on it . Thanks again
Stefan
Old 07-30-2015, 06:23 AM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Have you heard of Wilsonart?
Quartz, Laminate, Solid Surface Countertops and Metal Art | Wilsonart
Little Texas company, making high end goods. When you drive by you can't even smell the place like some other factories once were.
I have used their stuff for all my home improvement projects with exception of the last one which used granite in my home.
Channing
WBCCI# 30676
Old 07-30-2015, 06:54 AM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Consider the added weight of solid countertops.
Doug and Cheryl
Old 07-30-2015, 06:59 AM   #9
submariner's Avatar
1948 22' Liner
1989 34' Limited
I'll check on Wilson art . See what pricing they have . Thanks. In regards to weight : if I use manufactured stone , it would be very thin with a metal backing . I have seen this before . Alternative I have seen real stone with the honey comb backing . This is light weight as well but expensive :-)
Stefan
Old 07-30-2015, 07:08 AM   #10
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
When we did ours we went from Curava (resin/glass - manufacterer couldn't guarantee it wouldn't crack), Corian (used in some models but cracks reported) to laminate which allowed us to match the night-stand, dinette table and fridge door to the counters. So I would vote for laminate. Some of the high end laminates are available with profiled edging if if installed properly are almost identical in look and feel to machined stone/synthetic.
martin300662 is offline   Reply With Quote
Old 07-30-2015, 07:42 AM   #11
submariner's Avatar
1948 22' Liner
1989 34' Limited
Thanks a lot , that helps . Do you guys think, I can just lay over the existing laminate with new one ? It would surely help on the nightstand and the dining table ? Kitchen need to be replaced cause it is slight warped and bath was rotted out cause it got wet :-)
Stefan
Old 08-01-2015, 09:53 AM   #12
lcurrie's Avatar
2005 19' Safari
You can lay over top of existing as long as the existing is not peeling.
Lynn
Austin, Texas
2005 19' Safari, Toyota Tundra
2 Small and Spoiled Dogs
lcurrie is offline   Reply With Quote
Old 08-01-2015, 10:06 AM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
The new high pressure laminate from Wilsonart has nice edging...
Laminate Countertop Surface Edge Options | Wilsonart
Channing
WBCCI# 30676
Old 08-01-2015, 11:02 AM   #14
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I used the Wilsonart Winter Carnival with the crescent edge in my coach remodel. It seriously looks like granite. Check it out.
corian color preferences and vinyl floor choices? 2airishuman General Interior Topics 9 02-28-2005 06:57 PM
mattress choices ? vajeep Upholstery, Blinds, Walls & Interior Finishes 6 02-23-2005 05:22 PM
Header choices ALANSD Mechanics Corner - Engines, Transmission & More... 5 01-31-2005 02:07 PM
choices choices technautica Our Community 7 12-23-2003 05:46 PM
need to install a water heater...choices? pixie Water Heaters, Filters & Pumps 6 03-20-2003 06:24 PM
