Old 11-09-2012, 09:18 PM   #1
1975 Argosy 26
Des Moines , Iowa
counter top remove
hello,i've got a 1975 ARGOSY 26 FOOT. I'd like to know how to remove the counter top around the stove and sink.THANK YOU. SEMPER FI ANDY
andy jackson is offline   Reply With Quote
Old 11-09-2012, 09:24 PM   #2
Ottawa , ON
Well, it's much like at home: tap set out, clamps under sink off, undo sink drain(s), pull out sink.
I think there are usually screw at the back underneath holding it to the wall. If your model has a countertop stove, you may need to take that out too.
Old 11-09-2012, 09:34 PM   #3
webspinner's Avatar
Menlo Park , California
If you have a cooktop/oven combination, does that need to come out for the counter to come off, or can it stay in its place?
Barbie
Our travel and renovation blog: http://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Old 11-10-2012, 06:19 AM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Andy your stovetop/oven should come out rather easy. Caution: it is heavy and awkward to lift. Remove the stainless stove top to access the top of the unit. I believe there are 4 screws that run through the flange top into the cabinetry. Slide stove forward, it just rests on the countertop, and unhook both the gas line and electrical wire to light (if your oven has one). I rebuilt our galley as the original was in pretty rough shape. Dropped stove right back in.
Indiana, PA
PA TAC-5
WBCCI 4871
ID:	172407   Click image for larger version
Roadrunner is offline   Reply With Quote
