Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 04-13-2008, 11:24 PM   #1
Profile:  1972 23' Safari
Tallassee , Alabama
Counter Top Gasket Material
I need / want to replace the kitchen counter tops in my 72 Safari. The edges where it meets the walls is a rubber gasket. I would like to use a similar material (particularly where I am sealing above the fridge) but can't find it.
Does anyone know of a source or a good equivalent?
Tom Bray
Tom Bray is offline   Reply With Quote
Old 04-14-2008, 03:13 AM   #2
Commercial Vendor
vinstream's Avatar
Profile:  1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Well I live in Colorado and I go to a place called... http://www.keystonbros.com/index2.html
They have many shapes of rubber seals and edging products!
Try your local upholstery supply places... The ones that carry Marine and Automotive products should have what you need. Remember Airstream in most cases used off the shelf products... many still in use today!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
vinstream is offline   Reply With Quote
Old 04-14-2008, 03:13 AM   #3
Commercial Vendor
vinstream's Avatar
If you post a picture of it I am sure someone knows were to find the original!
www.VINSTREAM.com
WBCCI # 1962
Old 04-14-2008, 11:38 PM   #4
Tallassee , Alabama
Here is a photo of the trim piece. What it does is seals the counter to the wall without using any sealent.
Old 04-15-2008, 04:41 AM   #5
thinking outside the box
Commercial Vendor
62overlander's Avatar
Profile:  1962 26' Overlander
1954 22' Safari
1954 22' Safari
Catonsville , Maryland
I bought some from Outwater Plastics. I paid $1.28/ foot. It worked perfect for me, but might not for some, due to it only coming in clear. I also had to buy a 100' roll, of which I now have too much. If you are interested, I could send you a chunk to compare. How much were you needing? If you only need enough for a countertop, I could sell it to you at cost. I will need to use it again when I re do the front half of my trailer next winter.
62overlander is offline   Reply With Quote
Old 04-15-2008, 01:33 PM   #6
Tallassee , Alabama
The color seems fine, probably better than the tan color of the old stuff.
I probably should get at least 20 feet of it so that I have some room to change my mind / make a mistake.
What is the stuff called? I looked on their website and couldn't find it. I am trying to decide if I could use that stuff for other things after I am done reworking the kitchen. Otherwise your offer sounds great.
Tom Bray
Old 04-15-2008, 03:26 PM   #7
Tom Nugler's Avatar
Profile:  1972 25' Tradewind
McHenry County , Illinois
I've been looking for that seal for a couple of years. Being kind of a low priority I keep forgetting about it. Mine is a very light colored beige.
I tried Inland RV at one time with no luck. Looked at the Keystone link and got lost in the product list. If anyone could post a good link you would make me a "happy camper".
Tom.
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Old 04-15-2008, 06:20 PM   #8
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
I used this rubber Trim Insert from Camping World.
I just stapeled it to the back edge of my counter in the bathroom and under the front counter.
When I started running out I just cut it in two length wise and stapeled it with the curved lip coming over the top edge.
You can see how it looks on the second photo here.
Looks like it even comes in different colors too!
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 04-16-2008, 10:35 PM   #9
Tallassee , Alabama
With a significant bit of help from "Ganglin" I was able to find the following link:
http://www.outwater.com/pdf_files/opi/Extrusions.pdf
The part number is 444-CL
There are several other items I will want to get from them.
Tom Bray
Old 04-25-2008, 12:21 PM   #10
airstream4's Avatar
Profile:  1997 34' Limited
1963 22' Safari
Troy , Michigan
Just bought some on ebay
eBay Motors: Rv trailer marine vinyl gimp cabinet MOLDING TRIM white (item 270225118509 end time May-01-08 21:27:30 PDT)
Ebay item 270225118509
sounds like what your looking for
Paul
Troy MI
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Sink and counter top replacement slimitch Cabinets, Counter Tops & Furnishings 8 01-07-2008 06:24 PM
Gasket Material for Kitchen Fan Cover bevman Roof Vents, Skylights & Fans 1 06-28-2007 08:39 PM
1968 Door gasket material Gen Disarray Doors & Locks 1 05-15-2007 08:34 AM
removing counter top dmadam Cabinets, Counter Tops & Furnishings 6 01-12-2006 04:55 PM
resurfacing bathtub and counter top davidlaxson Sinks, Showers & Toilets 14 09-23-2003 02:30 PM
