Old 12-15-2013, 02:15 PM   #1
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Corian on range cover
Could not find an answer to this using the search function, so here goes:
My 99 Excella has Corian attached to the metal fold down range cover, so that in the down position it matches the countertops. It is coming loose. It's only loose enough that I can lift it about 1/2" on one corner. There are no screws, bolts, etc holding it down, so I assume it is held in place by adhesive.
Can anyone tell me what adhesive was used by Airstream when it was built at the factory? There is nothing in the owner's manual about this.
Thanks!
Alan
Old 12-15-2013, 02:29 PM   #2
2005 30' Classic
Burlington , Ontario
I can't answer your question, but if I were in your shoes I would give Airstream at JC a call. I don't know imagine they would have any problem answering the question to help you.
Worth a try.
Brian.
Old 12-15-2013, 02:32 PM   #3
1994 30' Excella
Mississauga , Ontario
probably silicone caulking.
Al
Al and Jean
TAC ON-3
Old 12-15-2013, 02:42 PM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I would guess silicone sealant or possibly a construction adhesive. Call JC and ask, they may know or they may not.
Aaron
WBCCI #XXXX AIR #2495
Old 12-15-2013, 02:42 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Worth a try.
Brian.
I left a message at Airstream Customer Support, hope to get a response tomorrow!
Al
My thought too, but I wanted to make sure before applying silicone to anything.
Alan
Old 01-10-2014, 07:23 PM   #6
hang up and drive
kry226's Avatar
2010 30' Classic
:) , Germany
Mine is held down with double sided tape.
2004 Dodge Ram 2500 5.9L Cummins 4WD (SOLD)
2010 Classic 30
ProPride P3-1400
kry226 is offline   Reply With Quote
Old 01-11-2014, 07:03 AM   #7
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I appreciate that information!
I got no call back from JC when I contacted them.
Alan
