Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 04-20-2008, 08:25 AM   #1
Profile:  2001 30' Limited
Fonthill , Ontario
Corian Counter Top
My coriaon counter top cracked near the sink in my '01 AS. Tried to glue it ..unsuccessful. Any suggestions???
6thChief is offline   Reply With Quote
Old 04-20-2008, 08:47 AM   #2
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Airstream Registry
I would try a Corian dealer in your area. We had a crack in our white Corian countertop in our home a number of years ago. We had it repaired by a Corian dealer, and could hrdly see where the crack had been.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 04-20-2008, 10:10 AM   #3
Fonthill , Ontario
Corian
Thanks for that Moosetags, has any one attempted a corian fix at home?
Old 04-20-2008, 11:18 AM   #4
Profile:  Currently Looking...
la mesa , California
That countertop didn't crack for no reason. I have repaired many tile and
granite decks in the last 25 + years(no corian). Flex, Temperature, and
poor installation are all possible reasons and each should be considered
before a repair is made. BBBBut the number on reason for a crack at the
sink corner (the weakest area of counter) is some fool placed there big
wide heavy WHAZOO where it shouldn't be. Call a corian fabrication
shop would be my answer allso.
Ron E.
redwords is offline   Reply With Quote
Old 04-20-2008, 12:02 PM   #5
Foiled Again's Avatar
Virginia Beach , Virginia
It's a specialist's job
Anyone CAN learn to do anything.
But...
Unless you want to get into the business of fabricating and installing Corian, this IS one that's better left to the professionals.
There are very specialized adhesives needed to repair manufactured stone surfaces, very limited working times, rather wierd joining techniques. With RV Corian especially (very thin or even a 1/8 inch veneer over plywood), unless you know exactly what brand, and when it was manufactured odds are you'll end up with a worse mess than you currently have. I have customers who fabricate and install these countertops, and I've been able to watch some of the processes. Corian can even be heated and bent - carefully! The neat thing of having it in your Airstream is that you can take the work to their shop and avoid a travel charge!
Paula Ford
VA-6 yah!
HONK if you love Jesus,
TEXT if you want to meet him personally.
Old 08-01-2008, 09:11 AM   #6
Traveler
rd tighe's Avatar
Profile:  2007 25' International CCD FB
midland , Michigan
we use speed glue from fast cap.com it is just supper glue with a spray to speed it up get the thin glue place it in a diabetic needle (you can get at drug store) shoot it in the crack spray and repeat till full then sand with 180 grit to 220 grit then polish with a green Scotch Brite when sanding be careful not to sand a dip do a big area i would get a small square palm sander for both the sandpaper and the Scotch Brite
rd tighe is offline   Reply With Quote
Old 08-01-2008, 09:51 AM   #7
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
Wood Magazine did some articles on Corian a few years ago. I tried to purchase some to do my own home bath. No one would sell it to me. However I was able to get some cutoffs, sink blanks etc.
It really machines nicely with a router, I think I used super glue to glue it together. Really is NO mystery, google around.
and as rd indicated you can use finer sandpaper to get the finish you desire. Go all the way up to 2000 grit for a very shinny surface.
www.popasmoke.com
Proud Appellation American
Vine View Heights, by appointment only
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 08-01-2008, 03:38 PM   #8
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
Profile:  2006 30' Safari
Fayetteville , Georgia
Try E-bay.
Family of Disney Fanatics
WBCCI# 4821
streamin across america
Sink and counter top replacement slimitch Cabinets, Counter Tops & Furnishings 8 01-07-2008 05:24 PM
removing counter top dmadam Cabinets, Counter Tops & Furnishings 6 01-12-2006 03:55 PM
Corian Counter Tops Rod Pease Cabinets, Counter Tops & Furnishings 24 01-22-2005 05:35 AM
resurfacing bathtub and counter top davidlaxson Sinks, Showers & Toilets 14 09-23-2003 01:30 PM
Corian Counter tops smily Cabinets, Counter Tops & Furnishings 4 11-27-2002 07:31 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
