Old 06-08-2010, 10:45 PM   #1
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Converting an Undermount Sink
Sheesh, I am one cheap SOB. Can't stand paying hundreds for a sink. So I find this Suneli 1815 undermount sink for just over $50. It's about the right size and I like the 7" depth. So as part of making the new counter top (the particle board "prototype" lasted 7+ years, which is waaay overkill), I thought a sophisticated undermount would be just the thing. When it arrived, the top flange looked so attractive I thought I'd try making it into a top mount.
Undermount sinks have no cleats for pulling the sink down to the counter. I used some resin left over from the Pygmy kayaks and glass to attach some homemade cleats. Making the cleats required some 1/8" scrap, some 5/8" X 3" strips of 0.040, and a vise. Then the paint on the outside of the sink was roughed up with 80-grit and the cleats were epoxied on.
Name:	IMG_1036 epoxied clip-s.jpg
ID:	104469 Click image for larger version
Name:	IMG_1037 clip in vise-s.jpg
The flange on the sink is so attractive [to me] that I decided to take a big gamble and expose it, flush with the counter top. This required making a template and using a pattern/template cutting router bit to relieve about 3/32" into the plywood. The template was drawn using the sink, but was cut with a sabre saw and then filed/sanded to as perfect a fit as I could manage, manually.
Name:	IMG_1040 templae outline-s.jpg
ID:	104471 Click image for larger version
Name:	IMG_1039 template-s.jpg
Name:	IMG_1041 surface relief-s.jpg
After that, installation was a snap. The relief area wasn't perfect. There are gap variations of maybe 1/32", which doesn't sound like much, but it's easily visible if you look (that's the risk of doing an inlay, I guess). On the other hand, for a first time using a router like this, I'm giddy happy. The J-trap, as in all my other sink installations, is recessed back towards the shell to allow for more drawer space under the sink.
Name:	IMG_1071 gaposis-s.jpg
ID:	104473 Click image for larger version
Name:	IMG_1073 J-trap-s.jpg
The slight "S" curve edging (cherry on the burch plywood), where the counter gets wider, was cut using the same template idea. Why not go to excess when you discover a new technique?
Name:	IMG_1070 installed-s.jpg
Zep
Old 06-09-2010, 11:53 PM   #2
1992 29' Excella
THE RANCH , Texas
Howdy from TEXAS!!! You did a fine job on that sink.....pics will help me to work magic on my new pretty undermount sink.....
Pray, sleep, and enjoy life.....adios...Callie
TAC TX 42
callie is offline   Reply With Quote
Old 06-10-2010, 05:53 AM   #3
The handy accountant
pageclot's Avatar
1976 27' Overlander
Scarborough , Ontario
Images: 21
That looks beautiful. And you recovered so much counter space!
Q: Is that a veneer counter top?
Other Q: Is that tape you put around your cut line so you wouldn't chip up the veneer?
_____
Kevin and Leah
Accountants who tow sans regret
"I nostri cuori e le menti appartengono al flusso d'aria"
pageclot is offline   Reply With Quote
Old 06-10-2010, 06:42 AM   #4
1975 31' Sovereign
1977 23' Safari
Yes, very thin birch.
No. That's the cut/relief before I cut out the center (you can see the line where the full cut is about to happen). This plywood (unbeknowst to me when I bought it) has two layers of very fine particle board as part of the five-layer sandwich. It's very heavy and I won't be getting it again, but it does cut very nicely. Anyway, that's why the relief area is so uniformly brown. The template helped prevent chipping, since it was down tight to the surface. I did a little test first to make sure.
Part of that "recovered" space is from moving the bedroom aft about a foot. That little task is covered in my Overlander thread.
Zep
Converting Airstream For Vending cornerfoods Interior Restoration Forum 3 04-28-2010 07:05 AM
Not converting to LP --- I'll try this DrPlay Generators & Solar Power 5 03-16-2009 10:31 PM
My Converter stopped converting thecatsandi Batteries, Univolts, Converters & Inverters 16 01-03-2008 10:05 AM
Converting to Bubble PoconoAir 1950-1955 Flying Cloud 27 02-05-2007 08:37 PM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
