Old 04-27-2015, 03:40 PM   #1
jhart657's Avatar
2007 25' Classic
1993 21' Sovereign
Elm Grove , Wisconsin
Changing surface mount hinge to euro-style
Airstream cabinet experts,
Has anybody changed out the traditional style surface mount old school hinges found on the Classics to the new Euro-Style hidden hinges? We just bought an '07 25' Classic Limited with the hickory interior. I would love to change out all the hinges and door/drawer hardware to something more exciting. Your thoughts and ideas would be appreciated!
Juergen
jhart657 is offline   Reply With Quote
Old 05-13-2015, 11:47 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
There's youtube videos on it. You'll need a drill press and a special hole boring bit, plus a jig and a drill stop. I've seen it done, but I'd be ultra-careful about trying it.
Old 05-14-2015, 05:33 AM   #3
aquinob's Avatar
Portsmouth , Virginia
You need a certain thickness to the door. Most of the hinges require a 32mm hole that has to be placed a specific distance from the edge. Generally rail and style type doors are ok and any door that is at least around 1/2" or more in thickness. They sell jigs that can make it easy to bore consistent holes. I prefer to use a drill press to a hand drill so that the holes are perfectly vertical when the door is laid flat.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 05-14-2015, 05:34 AM   #4
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Euro Hinges
Juergen...I don't see where this would be a problem. While I haven't updated any existing cabinet doors, we have built new Airstream cabinets and always use the Euro-style hinges. The hinges are spring loaded and hold the doors closed better than surface mount hinges. As mentioned, you will need a plastic guide that sets your center point for drilling door frame and the corresponding drill bit. We started using a drill press but found we could freehand with battery drill just as well. Good luck!
Bob "Roadrunner"
Indiana, PA
TAC PA-5
WBCCI 4871
Roadrunner is offline   Reply With Quote
Stud Mount TV Mount on Shower Wall??? BASE729 Audio, Video & TV 0 11-29-2014 04:31 PM
Interior 12V pancake/euro-style lights w/LED bulbs harleyag70 Airstream Classifieds 1 03-03-2014 04:57 AM
Changing refrigerator surface so magnets stick karenjude Refrigerators 8 11-29-2009 08:21 PM
Flush Mount or Surface Mount Zac&Kristin Water Heaters, Filters & Pumps 10 01-13-2008 06:59 PM
Euro camping with an Airstream golddigger Shipping & Export/Import 6 03-13-2007 03:06 PM
