Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 06-03-2002, 06:41 PM   #1
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Talking Must be sick of me by NOW- Tambour Door repair
Givin up on buy Tampour doors for my 71'. Bit the bullet and started to fix them, I think??? Took all the slats apart piece by piece and cleaned them up. I intend to glue them back on a canvass cloth { which is the way new doors are manufactured today} Pray for me. Any suggestions???
niftypkg is offline   Reply With Quote
Old 06-12-2002, 05:49 PM   #2
Profile:
Question Tambour
I have a 1973 Overlander with rotten Tambour. I have ordered the replacement wood tambour and have started cutting the pieces. I have a question for you since you are already involved in the project: How do you remove and replace the tambour from the cabinet under sink and other cabinet near table? (Ones for above cabinets have been easier.) Very curious as can't quite figure out. I can be reached at repodog@aol.com I will be going full force on this project on Sunday as for Father's day, I get 7 hours of restoration time from family....
Repodog is offline   Reply With Quote
Old 06-12-2002, 07:44 PM   #3
Edie's Avatar
Profile:  Dallas , Texas
Unhappy Under Sink Tambour Removal
Okay…just remember that you asked the question. The only way we can see to remove the tambour on the kitchen sink cabinet is to first remove the sink and countertop.
Hey…don’t kill the messenger. And if you get a better suggestion, please let us know.
Edie
Edie is offline   Reply With Quote
Old 06-13-2002, 06:25 PM   #4
niftypkg's Avatar
Cornville , Arizona
Thumbs down Tampour Doors
Kill the messenger!! There are two rivets in the left [ and right??] columns behind the veneer in the front that tie the track channel to the column. Both tampour doors slide on that track, at least on my 71' Int.
Old 07-05-2002, 11:11 AM   #5
javah's Avatar
Profile:
Images: 14
You do not have to take the sink out to replace the tambour. Take a dremel tool and cut the inside track on the top and bottom about 1 inch long. You then can roll the tambour up and start feeding it from the inside. I hope this help is not too late.
javah is offline   Reply With Quote
Pingbacks are On
Replacing Tambour [Credenza] niftypkg Cabinets, Counter Tops & Furnishings 5 01-16-2007 12:36 PM
Tambour Alternatives for '78 Argosy Minuet overlander64 Cabinets, Counter Tops & Furnishings 8 03-31-2003 07:51 PM
Tambour Door Resources InsideOut Link Archive 4 09-23-2002 03:12 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 08:34 AM
Tambour..... Chuck Cabinets, Counter Tops & Furnishings 4 07-22-2002 01:00 PM
SEO by vBSEO 3.1.0
