Old 07-19-2010, 12:51 PM   #1
cyclegirl47's Avatar
2002 27' Safari
Sacramento , California
Can you paint or reskin cabinets?
We have a 28ft 2002 Safari. The cabinets are "oak" laminate. Can we paint them or reskin them without getting all new cabinets? Any advice or suggestions would be appreciated
cyclegirl47 is offline   Reply With Quote
Old 07-19-2010, 02:39 PM   #2
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
I would think you should be able to do either. I suspect painting would be the cheapest, but would "look" painted. Putting a veneer over the cabinet and door surfaces would look more professional. Maybe check with a local cabinet making business and get an opinion & quote to help you decide.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 07-20-2010, 11:20 AM   #3
chromechaser's Avatar
1974 25' Tradewind
kirkland , Washington
HI! We have a 1974 tradewind and we painted some of our wall panels with Home depots Behr Ultra paint. Its a primer and a paint mixed together. We used exterior grade. It worked well. Its fairly durable but it is susceptible to scratches just like any other painted wall. Hope that helps. J
chromechaser is offline   Reply With Quote
Old 07-20-2010, 12:07 PM   #4
2002 19' Bambi
Lafayette , California
Cyclegirl,
I believe your Safari has the same "oak" cabinets our 2002 19' Bambi has. That means vinyl wood-grained film over plywood with edge banding. The edge banding is plastic held on with a glue similar to hot-melt glue. If you cover the vinyl, you will need to make sure that the covering material adheres well to such plastic. That means selection of the proper glue and good surface preparation. If you paint, one of the new paints suitable for plastic (such as Krylon Fusion paint) might work best.
Despite the many disparaging remarks one hears about the vinyl covering, it is durable and washable.
Tim
Tim A. is offline   Reply With Quote
Old 07-20-2010, 12:21 PM   #5
lgastall's Avatar
1973 31' Sovereign
Hastings , UK
It may be worth checking out - http://www.airforums.com/forums/f39/...ors-62392.html
Mermitate - The Airstream that is becoming a boat.
www.mermitate.com
lgastall is offline   Reply With Quote
Old 07-20-2010, 01:53 PM   #6
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
perhaps you can reface with 1/4" birch ply or similar, and then replace the edge banding with something that's 1/4" wider than the original?
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
Old 07-21-2010, 08:33 AM   #7
2002 27' Safari
Wink Thanks
Thank you all for the suggestions. I will be looking in to the possibilities.
If anyone out there has actually attempted this project please let me know Julie
Old 07-21-2010, 09:20 AM   #8
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
I used minwax clear polyurethane and it restored the tone of the wood...that is if they are faded or even scratched...kind of caught a little buzz there too...but all the wood is still with us.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
chassis paint question..paint experts? Spit Clearcoat, Exterior Paint & Trim 1 04-13-2010 01:23 PM
Paint or not to paint... that is the question tschat Sinks, Showers & Toilets 3 10-17-2009 09:16 PM
Red numbers paint? hand paint? Zstream Clearcoat, Exterior Paint & Trim 2 10-02-2008 11:35 AM
To Paint or Not to Paint My Dashboard Chaplain Kent General Interior Topics 8 02-23-2006 07:41 AM
Paint stovetop with high temp paint? ironfem200 Stoves, Ovens & Microwaves 4 02-19-2006 03:47 PM
