09-23-2016, 05:53 PM
#21
2017 25' Flying Cloud
Gold Country
To the OP.
Does the thought of building your own cabinets excite you? How long ago was your shop class?
I've built cabinets and furniture for years, semi professionally. This is what I tell people who want to build their own;
If you're on a budget, have all (or most) of the tools already, and want to try your hand at it, then I say go for it. If you'd rather spend your time doing something else and can afford a profession, do that. USUALLY a professional will build it faster and better, but they will lack some of the passion you can bring.
It is fun to know that you built it, but marriages are difficult enough without another project if neither of you want to tackle it.
Matt
09-23-2016, 07:22 PM
#22
1993 34' Excella
Estancia
, New Mexico
SuzyHomakr,
Where did you find that diverter faucet. I need a new one.
09-23-2016, 08:23 PM
#23
1988 32' Excella
Robbinsville
, New Jersey
Originally Posted by NorCal Matt
To the OP.
Matt
I agree with this and will add, maybe try a small cabinet fist and don't wait too long to give up if needed.
09-24-2016, 06:04 AM
#24
1972 29' Ambassador
Boynton Beach
Originally Posted by Lumatic
SuzyHomakr,
It's a Dura Faucet RV Lavatory Faucet w/ Shower Diverter DF-PL720A-CP
and a RV Shower Head & Hose Kit (Finish: Brushed Satin Nickel)
DF-SA130-SN
more pics of the vanity... The top is epoxy cloth coated OSB with cherry edges. Sea Dog Line push button latches.
... and that's MISTER Homemaker to you, fella!
09-24-2016, 07:56 AM
#25
1993 34' Excella
Estancia
, New Mexico
DF-SA130-SN
Mr. Suzy Homemaker ,
Your bathroom look would work perfect in my Tradewind. I make a motion you start your own thread on your project. Inquiring minds want to know.
Where are the Dura Faucet and Sea Dog latches available?
By the way my wife, Flordemayo, is something of a celeb and I am often called Mr. Flordemayo.
09-24-2016, 08:23 AM
#26
Dazed and Confused
Hillsburgh
, Ontario
Originally Posted by cliffcharb
One thing to take into account is weight. That's why as we rebuild our interior we are essentially making just the face frames.
As a skilled professional cabinetmaker who made his own cabinets for my 310 turbo diesel, this is the method I chose. I use soid pine rails and styles of varoius widths as needed and Dominoe'd them together with hardwood biscuits. The resulting faceframe if assembled square will always remain square. The gables I attached to the facframe were only long enough to mount drawer slides on to and that's it; no bottoms or backs and the counter top is the top.
The Domino system is the strongest way to attach faceframe components.
http://www.festoolcanada.com/power-tools/joiners/
As far as counter top material I use a form of solid surface laminate. It is 1/16" thick and white throughout, so no black backer lines.I also used 1/2" baltic birch as the underlay for the top itself.
Cheers
Tony
09-24-2016, 08:36 AM
#27
Gold Country
Originally Posted by Isuzusweet
The Domino is my next larger tool purchase. It is an awesome system. I've been using the horizontal boring table on my minimax, but the domino would say me a lot of time. I haven't experienced tool envy in while. Thanks for that
11-10-2016, 10:56 AM
#28
Groo The Wanderer
1964 26' Overlander
Tucson
Originally Posted by drboyd
I was "lucky" to find an inexpensive cabinet guy off Craigslist. Our deal was that he'd make the cabinets to my dimensions, and then I'd cut the back curves and around the wheel wells and the like, and I'd install them.
He was cheap and good, but it took for-freakin'- ever! The good part of that was that I'd go over to his shop, take him a chorizo burro for lunch, and watch and ask questions. I picked up a bunch of good tips on how the pros make cabinets!!
I also learned where he got his materials.
Pro tip: It ain't the orange place, the blue place, or the place where they sell you a tiny piece of onga-bonga wood for fifteen dollars. I ended up making the upper cabinets myself, as well as the dinette. I did have him make the doors for the upper cabinets, because I can't do mitered corners for crap. (That may change since I got a better [non HFT] miter saw).
The two most important tools to have will be a good table saw and a Kreg pocket hole jig set. A good miter saw won't hurt any, either.
Ditto! I used flat T brackets and bent them to attach to the back and inner mounting points so I could use olympic rivets to fasten to the inner skin. Kreg tool is perfect for these "smaller" project.
https://www.lowes.com/pd/Stanley-Nat...ackets/3169829
11-10-2016, 03:11 PM
#29
1976 25' Caravanner
Salt Lake City
, Utah
[QUOTE=IndianaDanO;1874836]Ditto! I used flat T brackets and bent them to attach to the back and inner mounting points so I could use olympic rivets to fasten to the inner skin. Kreg tool is perfect for these "smaller" project.
IndyDan:
I understand T brackets. I'm having trouble visualizing how you actually attached them to the inner skin and then used the oly rivets. Did the rivets go through the T brackets? And where were the T brackets attached to the cabinets? If you have any pictures that might help. Thanks.
11-10-2016, 05:49 PM
#30
Rich and Kat
Alexandria
Alexandria
, Virginia
DANGER DANGER ...
Festool tools multiply in the dark. It only takes you bringing one home. Then by parthenogenesis, one becomes three and three become fifteen and ... and ... same with Lie Nielsen. It only takes one ... and ... then you're broke!
On the serious side, should you become inflicted with this wonderful disease, be sure to hop on over to the festoolownersgroup... But know bankruptcy is the only possible cure.
Take care,
Rich
Rich
2017 Classic 30', ProPride 3P Hitch, 2016 RAM 3500 Laramie Crew Cab 4x4 SRW w/ 6.7L Cummins Turbo Diesel and Retrax Pro MX Tonneau Cover
KB2ZMF Save
11-19-2016, 08:27 AM
#31
Rich and Kat
Alexandria
Alexandria
, Virginia
I have something called the MortisePal Jig ... if anyone is interested it's in MINT condition ... (used twice?)
http://www.leevalley.com/US/wood/pag...,43000&p=66925
Search youtube and google for more info about it and PM me if you're interested in it... It does joints much larger than just a biscuit and more importantly, if you want to do real mortise and tenon joinery without having a dedicated mortise machine, or drill press/chisel process, this is an awesome way to go without spending the big bucks on the Festool stuff...
Take care,
Rich
Rich
KB2ZMF Save
06-14-2017, 06:59 AM
#32
Pleasant Plains
, Arkansas
BTW: Just installed my new custom mirror that I built...
That mirror is phenomenal!! What did you use for the light source? LED?
06-15-2017, 07:07 AM
#33
1972 29' Ambassador
Boynton Beach
<blush> Thanks!
The mirror is mounted on a piece of 3/4" ply. The LEDs are glued to the edge of the ply.
