Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
View Poll Results: Preferred cabinetry
Solid wood 12 80.00%
Tambour 2 13.33%
Other (aluminum etc, please explain) 1 6.67%
Voters: 15. You may not vote on this poll
Old 07-12-2003, 06:09 PM   #1
Rog0525
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Cabinetry, solid wood, tambour or other
Solid wood
Tambour
Other (aluminum etc, please explain below).
I'm not a fan of the tambour drawers and doors. Too many probs with sticking, misalignment, lost bins, etc. What is your ideal cabinetry?
Rog
Rog0525 is offline   Reply With Quote
Old 07-12-2003, 07:23 PM   #2
j54mark
Profile:
The tambour is a great idea, in theory. Lightweight, wouln't split or crack, has the ability to open up large areas for access. Frankly, Airstream's execution was pretty poor. The bins tend to be very space inefficient, and there is a lot of wasted space in the areas used for spiral rolls.
I have replaced all the tambour in my coach with oak rail and stile doors or with ordinary drawers, except the bathroom cabinet. The tambour there works well, and if it ever causes a problem I will definitely rebuild with new tambour.
Looking to the future, some bright person will figure out someday that travel trailers are not minature houses. Storage in general and cabinets in particular need serious rethinking. The Dean CCD is a step in a new direction, but I am not sure it is quite the path I want to follow.
Mark
Old 07-12-2003, 11:26 PM   #3
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
My kitchen tambours were missing. The PO replaced with cheap paneling sliding in the grooves and that was falling apart.
I replaced with 1/2" birch and stained. I am NO woodshop guy at all so you can probably do a much better job than mine.
You can see a picture at my website. The before picture is terrible, since I did not know it was going to be a before picture when I took it
The rest of the bottom tambours were broken or missing and I have not done anything there other the get rubbermaid bins that fit those locations.
Luckily the top tambours seem to work after some silocone spray.
The bathroom tambour works very poorly. But there does not seem to be a better solution since we shower in there.
http://www.telecom-pros.com/tim/airs...net%20Work.htm
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 07-12-2003, 11:52 PM   #4
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Solid wood, but not the heavy looking residential type with raised moldings...I like the simpler clean lines of the 60's and some of the newer ones, The CCD ones are pretty cool too IMHO.
Shari
Old 07-13-2003, 07:49 AM   #5
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Originally posted by InsideOut
Solid wood, but not the heavy looking residential type with raised moldings...I like the simpler clean lins of the 60's and some of the newer ones, The CCD ones are pretty cool too IMHO.
Shari
I also like the interiors of the current Safari and the International AS. Wilsonart Tropical Oak laminated surfces with rounded corners. European type concealed hinges. Bulletproof as regards to scratches, although Airstream still seems to have minor problems with edges such as the edges of my bathroom door. Maintanence consists of wiping the walls and cabinets down with furniture oil on a rag.
Given the option, I would choose the CCD flooring over carpet.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Feedback needed for real wood cabinets yukionna Cabinets, Counter Tops & Furnishings 49 05-11-2004 09:45 AM
Wood Veneer Furniture Project joshua32064 Cabinets, Counter Tops & Furnishings 5 10-05-2003 01:52 AM
Tambour Alternatives for '78 Argosy Minuet overlander64 Cabinets, Counter Tops & Furnishings 8 03-31-2003 08:51 PM
Tambour Door Resources InsideOut Link Archive 4 09-23-2002 04:12 AM
Tambour..... Chuck Cabinets, Counter Tops & Furnishings 4 07-22-2002 02:00 PM
test
