Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 04-03-2005, 07:57 PM   #1
Profile:
Question cabinet tambour not sliding
I just bought an 1979 International sovereign 29 foot. the interior cabinet rollers were stuck, I sprayed wd 40 on them and it helped for a few days, now I cant get in at all to even light my pilots to do a test on my appliances, any clues on freeing up the roller compartment system?
ravholette is offline   Reply With Quote
Old 04-03-2005, 08:13 PM   #2
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Run a board search on "Tambour" or "Tambor". Mine needed to be disassembled and cleaned to be made functional. Sometimes even that won't be enough. Silicone would be a better choice than WD-40. You are dealing with plastic and paperboard pieces the WD will gum them up and possibly detiorate some of the components. I have one that is particularly sticky, I am going to take it back apart and try waxing the slides and the tambour part and see if that helps, if not I will probably build a new tambour or come up with another door solution for that area.
Aaron
WBCCI #2449 AIR #2495
Old 04-04-2005, 08:51 PM   #3
Profile:
Rear end sagged, then dropped out on the road?
AuthorTopic ravholette
Starting Member
Posted - 04/03/2005 : 04:53:15 AM We just purchased a 1979 International with the rear end bath, and took it out on a maiden voyage. The rear end had a sag, the holding tank was cleaned. On the trip home the rear end dropped off and we had no option but to drag it home, it was eve and all the welding shops were closed. It looks like the whole compartment that is underneath the rear end bath dropped down, ripped hoses and lines and compartment with circles on it. I have the owners and service manual but they do not have diagrams of interior compartments beneath the flooring. What is this stuff that just fell out so that I have direction on how to repair or replace?
Jim Wilkinson
Paid Sponsor
USA
5554 PostsPosted - 04/03/2005 : 4:55:00 PM I'd post this at the fdollowing site. You'll get a lot more response there. I'm really sorry that happened to you.
http://www.airforums.com/
77/31'Airstream
99 GMC Suburban 454/4.10
WBCCI# 18248
S.F. CA area.
Sliding Cabinet Hardware LKappenman Cabinets, Counter Tops & Furnishings 5 10-20-2002 05:53 PM
Cabinet door latches 53flyingcloud Cabinets, Counter Tops & Furnishings 3 07-08-2002 04:28 PM
Door and cabinet knobs jcanavera 2001 Safari 0 07-07-2002 11:19 PM
Cabinet Catches Danno Cabinets, Counter Tops & Furnishings 1 06-18-2002 10:12 AM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 08:22 PM
