Old 04-23-2010, 06:20 AM   #1
Safari 62's Avatar
1962 22' Safari
2014 30' Flying Cloud
Grayling , Michigan
Talking Cabinet refinishing
Removed cabinet hinges and hardware last night. Using ryobi mouse sander to remove rippled veneer . Did one door and turned out beautifully. Going to restain a cherry color to match the allure cherry vinyle flooring. Originally bought high gloss, but I am going to return this to Home Depot for a satin finish. I beleive that is what most interior cabinets have. Feed back on this would be appreciated.Linda
Safari62 Always looking for the silver lining in the gray clouds...
Safari 62 is offline   Reply With Quote
Old 04-23-2010, 07:54 AM   #2
Yes, satin is closer to the original finish, but it's really a matter of personal preference.
One trick-- if you want to put on multiple coats and you want a satin finish, use a clear high gloss for the first several coats, and then use satin for the final coat. If you use satin for ALL coats, sometimes it tends to muddy up the wood grain a little bit.
And I definitely recommend using multiple coats-- the temperature and moisture variations in a trailer can be much tougher on wood finishes than they would be in your house, and multiple coats will help preserve the wood.
Be sure to post some pictures of the process, we love pictures around here.
Good luck!
Old 04-23-2010, 08:12 AM   #3
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Just a note: the flat and semi-gloss effect is achieved with microscopic silica glass dust with a side benefit of increased sunlight UV protection as the silica glass absorbs it before it can reach deep in the finish and wood...
Good tip on using a satin, semi-gloss or flat over base coats of clear - I have projects that could've - should've used that on :/
Old 04-24-2010, 03:35 AM   #4
Safari 62's Avatar
1962 22' Safari
Grayling , Michigan
Thank you for your replys and I will post pictures soon. I took my camera outside yesterday and forgot to take pictues. I used 2 layers gel stain to prevent drippage. It didn't say if it was sealed or not, so I bought tung oil to finish it off. I haven't applied that yet. Years ago, I had good results using the tung oil on a cherry wood kitchen table.
Old 04-25-2010, 06:55 AM   #5
Safari 62's Avatar
1962 22' Safari
Grayling , Michigan
I put the first coat of tung oil on cabinet doors yesterday. Really brings it to life. Second coat goes on the doors today. I used a mahogany color stain gel that matches the allure vinyl flooring that will be put in. The cherry color would have been too light. I am going to paint the walls sage green to contrast the floor and cabinets. Linda
Old 04-25-2010, 09:29 AM   #6
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
You could put about 3 or 4 coats of Tung Oil (buffing between coats) I do my furniture projects this way.Then just oil now and then to keep new looking.Once there is a finish, the oil won't soak into the surface.
bwaysteve is offline   Reply With Quote
Old 04-25-2010, 09:37 AM   #7
jwvastine's Avatar
1987 23' Sovereign
Tucson , Arizona
Can't wait to see the photos as I'm planning to do the same thing. Just haven't decided on color.
What brand gel stain did you use?
Judy
jwvastine is offline   Reply With Quote
Old 04-25-2010, 09:56 AM   #8
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Cabinet Refinishing
We refinished the cabinets in our 65 22' Safari this past fall with Watco Oil in red mahogany. We love the warm feel. Please share your pics.....Tim
ID:	101219   Click image for larger version
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 04-26-2010, 06:39 AM   #9
Safari 62's Avatar
1962 22' Safari
Grayling , Michigan
Nicely done. I love it and it is warm and inviting.
Old 04-27-2010, 08:49 AM   #10
jwvastine's Avatar
1987 23' Sovereign
Tucson , Arizona
Tim, did you sand the old finish off completely? I've never used oil for refinishing, but have used it for new construction. What kind of wood are the cabinets?
The finish is beautiful. Nice job.
Judy
Old 04-27-2010, 09:51 AM   #11
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Cabinets
The wood is Mahogany and had never been varnished just oiled (we were lucky). We lightly sanded everything including water spots etc. and tried to make them blend. Then we applied 4 coats of Watco oil (red Mahogany). We let each coat dry for a day then sanded again very light using steel wool and recoated. After the final coat dried we buffed using very soft cloth. We found that the more effort we put in the greater the results. Best of luck....Tim
Tim
TAC MI 14
refinishing emblems pinkflamingoes Cleaning, Stripping & Polishing 18 03-28-2013 11:41 PM
Refinishing cabinets valentine Cabinets, Counter Tops & Furnishings 17 02-06-2009 01:31 PM
Cabinet Refinishing Rat Pack Cabinets, Counter Tops & Furnishings 7 10-20-2006 08:41 PM
Refinishing one segment jhart657 Cleaning, Stripping & Polishing 3 09-16-2005 04:30 PM
help with refinishing cabinets yaakman Cabinets, Counter Tops & Furnishings 9 09-06-2002 07:01 AM
