Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 10-19-2008, 10:04 PM   #1
Profile:  1975 Argosy 22
Charlottesville , Virginia
Cabinet Makeover Question
I have a '75 Argosy 22' and I want to "resurface" the original floor cabinets with white formica. The problem is that I want the formica to slide under the lip of the door framing metal. So I either take the doors/cabinet faces apart or just find a place that has the metal and rebuild the fronts. Has anyone done this before?
uniquemicro is offline   Reply With Quote
Old 10-19-2008, 11:43 PM   #2
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
could you post a pic... It might help...
Jason
2008 5.7 L V8 Sequoia w/tow package (dark green)
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-20-2008, 05:51 AM   #3
boatdoc's Avatar
Profile:  1973 Argosy 26
Norristown , Pennsylvania
Originally Posted by uniquemicro View Post
I have a '75 Argosy 22' and I want to "resurface" the original floor cabinets with white Formica. The problem is that I want the formica to slide under the lip of the door framing metal. So I either take the doors/cabinet faces apart or just find a place that has the metal and rebuild the fronts. Has anyone done this before?
Hi uniquemicro; The only way that you can do it is to remove the panels. Router out from back side enough plywood from it's thickness to compensate for the Formica, which you will add to the face. There is usually about 0.020" clearance to begin with, unless your face ply is swollen with moisture. Be sure to router off deep enough to match the depth of the aluminum trim. Best to use is a spray glue made by North Star Chemicals, Inc "Star Stuk Clear HM". If you need more details PM me. Thanks "Boatdoc"
boatdoc is offline   Reply With Quote
cabinet formica
makeover readytogo General Interior Topics 5 03-19-2007 08:07 PM
RV Makeover jpurdy General Motorhome Topics 17 07-15-2005 07:08 PM
Restore vs. Makeover andreaszabo Our Community 8 07-10-2002 06:57 AM
