Old 05-26-2015, 08:38 AM   #1
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Cabinet latches?
Need a replacement cabinet latch for a 2010 Flying Cloud. Anyone found these locally or must one order them?
ID:	239269   Click image for larger version
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 05-26-2015, 10:15 AM   #2
2005 19' Safari
GLENDALE , AZ
This latch comes in several different pound-ratings, so this one might not be the exact one you want: Southco Grabber Catches - Amazon.com
Old 07-14-2015, 03:33 PM   #3
Alphonse's Avatar
Lower Alabama , USA
Problem solved:
Here is what I bought and replaced the broken one with in my pantry. It is a 10# pull and an exact duplicate of what was installed. RV Designer Model H316. I found them available at Camping World or Amazon. Here is the Amazon Prime link:
Amazon.com: RV Designer H316 Black Push Latch: Automotive
This is the 10 lb. pull version. The 5 lb. pull is Model H315. I now also have a spare of both.
Alan
Air #64439
TAC AL-8
2018 Canopenian
Old 08-01-2015, 09:57 AM   #4
lcurrie's Avatar
2005 19' Safari
I replaced mine with a magnetic version that I found at Home Depot.
Lynn
Austin, Texas
2005 19' Safari, Toyota Tundra
2 Small and Spoiled Dogs
lcurrie is offline   Reply With Quote
Cabinet latches D Bishop Member Introductions 8 10-14-2006 11:10 PM
cabinet latches technautica Cabinets, Counter Tops & Furnishings 9 06-07-2006 08:40 PM
Cabinet/door latches cumminspch Commercial Listings 1 11-01-2004 02:39 PM
Cabinet door latches 53flyingcloud Cabinets, Counter Tops & Furnishings 3 07-08-2002 03:28 PM
