Old 08-05-2010, 01:33 PM   #1
1972 27' Overlander
hartsville , Tennessee
Cabinet attatchment
I am replacing my old cabinets with new, custom built cabinets. Is it best to attatch this cabinets back to the interior skin with screws or rivets?
doglickfarms is offline   Reply With Quote
Old 08-05-2010, 01:42 PM   #2
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Good question. We have all the mid bunk cabinets top/bottom out and are ready to replace with mahogany cabinetry. You are right that the original were riveted. We are planning on using angle aluminum attached with screws to the back of the face frame (overhead cabinets) and then rivet to the inner skin. Bunk cabinets will get anchored inside with pocket screws to the floor and again use angle aluminum to sidewall skin with rivets. My feeling is that original used rivets...should probably stay with rivets. Screws could back out from repeated vibration/bouncing of trailer. Would like to see what others have done. Good luck. Post some pictures of your progress.
TAC PA-5
Roadrunner is offline   Reply With Quote
Old 08-05-2010, 02:02 PM   #3
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
screws, with their short grip length, will over time loosen up. whereas a rivet swells on the other side of the hole, in effect squeezing the wall between the two ends of the rivet. brackets should be riveted to the wall, screwed to cabinet and floor.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 08-05-2010, 02:15 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
I intend to follow the OEM pattern, by and large. I want to make everything easily accessible. Almost everything I've removed from my trailer so far was attached with screws. It looks to me that the company that made the trailers bought rivets cheaper than they bought screws and I believe in some cases the choice was a matter of economics not engineering.
Anything I might want to access or change, I intend to screw.
Gary
new cabinet doors! Isadora All Argosy Trailers 1 08-03-2008 05:14 PM
cabinet extrusion bcass Cabinets, Counter Tops & Furnishings 2 04-01-2008 11:35 AM
mystery cabinet pjude Classic Motorhomes 8 10-01-2007 09:08 PM
Under cabinet LCD? FlyFishInn Audio, Video & TV 6 05-29-2006 08:56 PM
