Old 03-19-2017, 08:05 PM   #1
arden_dean's Avatar
1986 34.5' Airstream 345
topeka , Kansas
Images: 26
Cabinet Aluminium Extruded Angle
I'm looking for a supplier who has the Cabinet aluminium extruded angle that supports the upper cabinets it looks like its about 60 degrees.
ID:	281700   Click image for larger version
“The world is a book and those who do not travel read only one page.” – St. Augustine
arden_dean is offline   Reply With Quote
Old 03-19-2017, 08:18 PM   #2
arden_dean's Avatar
topeka , Kansas
Images: 26
ttt
Old 03-19-2017, 08:35 PM   #3
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Gotta picture of the extruded material you're looking for? Nice woodwork, BTW.
www.nesa.org
Air No. 6427
Old 03-19-2017, 08:44 PM   #4
arden_dean's Avatar
topeka , Kansas
Images: 26
here's a pic of 90 degree 60 looks the same only its 60. The angle I have is in use and hard to see where it is.
Old 03-19-2017, 08:59 PM   #5
1977 31' Sovereign
Sunset Valley , Texas
Have you thought about using an aluminum piano hinge? Couple that with this: http://www.vintagetrailersupply.com/category-s/427.htm and you would seem to be good to go.
Ian
Iansk is offline   Reply With Quote
Old 03-19-2017, 09:38 PM   #6
arden_dean's Avatar
topeka , Kansas
Images: 26
Yes I have, if I can't find any I'll have some steal bent at a custom fab shop.
Old 03-19-2017, 11:39 PM   #7
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I ran into the exact same situation. What I did was to rip an angled filler piece (crosshatched) and screw+glue it to the upper back of the (solid brown) cabinet front - where it would be concealed. This let me use just plain 90 degree 1-1/2" by 1-1/2" aluminum angle (in black), screwed to the wood angle and riveted to the inner skin.
This is an extremely lame picture, but the trailer is six miles away, so it's what you get.
Name:	Cabinet to roof section.jpg
ID:	281736   Click image for larger version
Old 03-20-2017, 01:01 AM   #8
arden_dean's Avatar
topeka , Kansas
Images: 26
that was plan c; however, it looks like it work well for you. I was thinking of using a hard wood like oak. The angle on mine will be different I copied the front cabinets exactly so they have a 30 degree incline making the ripped piece at an odd angle.
Old 03-20-2017, 11:37 AM   #9
drboyd's Avatar
1978 25' Tradewind
The angle for the ripped piece was just measured and duplicated. The wood on mine is knotty alder; it's not real hard, but it's reasonably light.
Old 03-20-2017, 03:16 PM   #10
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Why couldn't you just flaten out some angle aluminum? Or bend some sheet stock?
I do like drboid's method too.
bibbs is offline   Reply With Quote
Old 03-20-2017, 03:49 PM   #11
drboyd's Avatar
1978 25' Tradewind
I don't have access to a b ending brake, and it seemed like my usual method of "beat it with a hammer until it looks about right" would be a little too "casual" for this application. Plus, it met the cost criteria.
Old 03-20-2017, 04:56 PM   #12
arden_dean's Avatar
topeka , Kansas
Images: 26
yep i've done it that way too. Two piece of angle lots of clamps and a torch with a sledge hammer. I'm trying to find a better way.
Old 03-20-2017, 05:50 PM   #13
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We used piano hinge. Worked well.
Kay
Old 03-20-2017, 06:41 PM   #14
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Piano Hinge is a very versatile product for just about any use.
Look after your equipment, it will look after you.
MelGoddard is offline   Reply With Quote
Entry Door Frames Cast vs Extruded Distantdrummer Doors & Locks 6 04-20-2008 06:44 AM
Which is worse when towing, trailer angle UP or trailer angle DOWN? Streamer1 Towing, Tow Vehicles & Hitches 33 09-19-2006 09:43 AM
Looking for the extruded window hinge piece minot Windows & Screens 1 02-13-2006 08:53 PM
