| Building L sofa Need Help & Suggestions (Bob Villa)
I building a L shaped couch sofa, I laid out the first set of frames.
I used 3/4" wood cleats on the floor to uprights so far, I was thinking of using light guage L alum on walls to uprights.
The left side are 33" apart and the right are 24"" apart, I think I need another on the left side.
The (bottom) fronts are going to be fixed with either 1/4" or 3/4" cherry ply.
I would like to save the weight and $$ on the 3/4".
The seats are going to have hatches about 18" Wide by 10" front to back, but be fixed solid otherwise. I was going to use 3/8" ply but it will need support?
The seat backs also 3/8"
How would you suggest I frame out the rest of the supports or any other changes.
Thanks in advance.
'77 Sovereign Intl 31' CB '07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper WBCCI Time's a-changing Say no to Lawrence Welk attitudes
