Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 05-16-2008, 10:16 PM   #1
Profile:  1981 31' Excella II
Hendersonville , Tennessee
Hi Todd,
A service manual sounds good. I have the owner's manual but it just has basic operation stuff. Where is the best place to order one?
MJ
mj81excella is offline   Reply With Quote
Old 05-16-2008, 10:46 PM   #2
monocoque's Avatar
Profile:  1975 29' Ambassador
San Antonio , Texas
MJ, I got mine through the contacts on the Vintage Airstream Club website but you can also apparently order them online through the Airstream website. Here's the pertinent forum thread: Need Owners Manual. A service manual is as close to a set of blue prints for an AS as you are likely to find!
Todd
“Complications arose, ensued, were overcome...savvy?”
- Captain Jack Sparrow
monocoque is offline   Reply With Quote
Old 05-16-2008, 11:29 PM   #3
pics
I have some pictures. They are in the members photos category, under my user name. I guess you could search for 1981 excella2 and find them as well. I'm sure this is a simple process to the regulars on the forums. Here is a pic for this thread.
Name:	jenny's card 464 1000x749.JPG
Old 05-17-2008, 09:32 PM   #4
Todd, when I look for a service manual at airstream.com they don't have 1981 listed as an option. Should I get 80 or 82 service manual?
Old 05-17-2008, 09:33 PM   #5
62averlander, did you use a veneer on your cabinets?
Old 05-18-2008, 05:45 AM   #6
thinking outside the box
Commercial Vendor
62overlander's Avatar
Profile:  1962 26' Overlander
1954 22' Safari
1954 22' Safari
Catonsville , Maryland
I did a combination of things. My cabinets were constructed of different materials in a different method than yours. The major problem I had was de-lamination. The plywood had sucked up moisture from the floor and the hot/ cold cycles caused all the layers to separate. Anywhere that this had taken place I removed the plywood entirely and replaced it with new material.
ID:	60585Click image for larger version
I had to cut down the cabinets by 11mm also to compensate for the new cork flooring. When I did that I installed a piece of vertical grain douglas fir at the bottom to keep it all together and give a new attachment point at the floor. I used a Kreg jig to create pocket screw holes to put that on. Click image for larger version
ID:	60587Click image for larger version
Originally there was a gap left at the bottom to allow air to come into the cabinet and the rise and leave the top. I used an arched piece that still allowed for that and helps make the cabinet more rigid side to side. After the frame work was repaired, new 3mm plywood was glued and stapled to the frames. I used a router with a pattern bit to remove the excess plywood.
After that I filled all the holes and seams with polyester filler and sanded it smooth. I then veneered using a paperbacked veneer and BondRite contact cement. This is now what the wood looks like in fiddleback maple.
Sorry if I gave you too much info, that is my nature. In reviewing this, I could have answered your question with a simple "yes". I do want to say that, when I begin taking on clients for this work, I will only build them new. I won't take the slight chance that more de-lamination might (very unlikely) occur to the old plywood.
62overlander is online now   Reply With Quote
Old 05-18-2008, 09:10 AM   #7
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
What kind of toosel is a "Kreg jig"?
Pay no attention to the man behind the curtain- WoZ
Old 05-18-2008, 09:14 AM   #8
Commercial Vendor
1954 22' Safari
1954 22' Safari
It is the blue thing in the photos... it guides a drill bit at the right angle to make a pocket screw hole. It is a very simple technology and is used mostly to build face frame cabinets. A square drive washer head screw(also in the photo) holds the joint tight.
Old 05-18-2008, 09:15 AM   #9
Commercial Vendor
1954 22' Safari
1954 22' Safari
oh yeh, they sell it at both the orange and blue box....
Old 05-17-2008, 09:43 PM   #10
monocoque's Avatar
San Antonio , Texas
Check with the other source, Vintage Airstream Club. I had to make a phone call and leave a message but they will call you back. I think it best that you get a manual for your year model.
Todd
Old 05-18-2008, 09:03 AM   #11
62 overlander
thank you that is exactly the kind of answer I was looking for
Old 05-18-2008, 09:18 AM   #12
Commercial Vendor
1954 22' Safari
1954 22' Safari
62 overlander
You are extremely welcome. If you need any more help feel free to contact me.
Old 05-18-2008, 09:17 AM   #13
Royce's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
I want to build cabinets for my 81 excella and I was wondering what the best material to use would be. I've seen some solid wood cabinets and they looked heavy. I want to keep the weight down. any suggestions. Is there a better alternative to a rebuild? Also, is there a market for selling the existing cabinetry and/or appliances? I'm still in the planning/thinking phase, everything is still intact. I'm most interested in ideas for cabinets right now. thanks, mj
Alder is one option. It is not quite hard enough for a desktop or floor even though used that way. It is hard enough for cabinets and is very light for its strength. Alder is also used as a mimic wood as it stains easy and is inexpensive. You can also do frame and panel using 1/4" material for the panel to save weight. Take it one step further to stressed skin and 1/8" Finnish birch ply could be used. The canoe in my avatar is one example of stressed skin, the hull is 3/16" thick and weighs in at 27lbs. To put some perspective to the photo, I weigh in at 250 lbs.
Example of Knotty Alder used for a table.
http://www.airforums.com/forums/404446-post40.html
Example of Knotty Alder used for Dinette end panel.
http://www.airforums.com/forums/563283-post1292.html
Royce (KORKK) and Karen
AIR# 3913
'77' Minuet 6 Metre TV: '94' Wrangler, 4.0L inline 6, Ford 8.8 rear, NV4500 tranny, Old Man Emu suspension, 30x9.5 tires
Royce is offline   Reply With Quote
How level for building cabinets? pamelake Cabinets, Counter Tops & Furnishings 5 01-22-2007 12:01 AM
building custom bathroom / interior pinkflamingoes Cabinets, Counter Tops & Furnishings 33 11-26-2006 06:27 PM
RV Building Code wkerfoot General Repair Forum 9 11-01-2005 01:21 PM
? Building an icebox Stefrobrts Refrigerators 9 01-05-2005 05:56 PM
custom A/S cabinets husky Cabinets, Counter Tops & Furnishings 4 03-05-2004 07:36 AM
