My son want's to use diamond plate for the floor- and maybe the shower. At this point, if he wanted to do something just as crazy, I'd let him .He's putting in 15 hour days in 100 degree weather. suz
I would rethink the diamond plate for a shower floor real quick especialy if it is the stuff with the sharp grip ridge. Stand on it bare foot and you will see what I mean.
I'd go with stainless with a brush finish. We are retaining our fiberglass shower pan but the riser for the toilet (we have a wet bath) will be stainless as will the vertical walls. We will use a very thin sheet and glue it to the walls.
I'm pretty happy with the over all floor plan of our coach and we plan to retain as mush as possible and do a bit more of a restoration with a little bit of a tiwist. Do so stuff like shift the galley forward so I can get a bed I fit in better. Our overhead in the galley are made out of aluminum. While we plan to go back with the Zolatone we have concidered polishing the overheads and taking out the wood doors and doing the transparent doors with back lights like the CCD. See our photo album and there are a couple shots where you can see our overheads.
My best advice would be go to www.vintageairstream.com and look at the archive pictures and see what elements you like. My favorite floor plan since we have kids is the rear bedroom center bath layout. As our kids get older it would give us a little private space if were ready for bed. If I ever get a MH the 310 rear full bed is the ideal layout for us.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
Thanks Uwe. I personally don't see any reason for a tub; if I need a soak, I'm headed for the hot tub in our yard or a local hot spring or something. My husband couldn't fit in the old one to save his life and my daughter is now old enough to take showers. So the tub is probably way too much work and not worth it.
Yep suz, we're checking all plumbing and systems first. The round sink by the way that you have is a stroke of GENIUS, a perfect example of thinking out of the box. We'll replace the belly plan and floor, fix frame where it needs it, and get that ready before we start interior remodel.
We pretty much just want to aluminum veneer the inside and just make the rest a combination of what "looks nice" and works, with affordable materials; formica countertops (they're not as hideous as they used to be!) wood cabinets and a woodgrain type Pergo floor to warm up the aluminum effect, if we even put aluminum throughout the whole thing. We might use some kind of carpet material for the walls, who knows?? But the "design" as in combination of materials, colors, etc. we're not going too fancy. Just durable and nice looking. So we're not picky about plans and only going for the CCD look in a limited fashion; in other words, anything other than that old gross vinyl on the panels.
So, a shower isn't that hard to find, I'm thinking? Just a basic step-in with a curtain that snaps to the walls, hand nozzle?
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
Ingrid, I am in the same boat as you as far as my interior goes.I tore the whole thing apart in a couple of days and brought it to the dump.I should have kept the tub,sinks and a few samples of how cabinets were made.The trailer was so moldy I did not want to keep anything and did not want to bring my camera in to take pictures of how things were put together.I thought I could remember how things are built as it is mostly 1/8" ply on 1x2s.The problem is the devil is in the details.When I get to the point that I can start building cabinets I hope I can find someone near me that has a vintage Airstream that I can "monkey see monkey do".I kept the old floor boards and that will help with the dimensions of the layout at least.
The same has happened to me with the frame off floor replacement.It is taking more time reassembling the body to the frame as I took no pictures or measurements of where frames meet floor.So before that comes apart take as many photos and measurements as you can.
I was checking out some of the new CCD models at the Sky River dealership in Paso Robles, Ca recently and noticed that the manufacturers decals were still on the shower enclosures... seems thay are made in Indiana by a company called Ultra Glass. I couldn't find much info on the web about them so I suspect they only do wholesale. If it was not too pricey I would consider using one of those in a bath remodel.
Hey there Ingrid! Well you can take solace in the fact that others learned from your mistakes! I haven't thrown out anything from my Safari and a lot of that is due to your warnings to me. But in any event my bathroom (while presently not in the trailer) is intact and I documented it's disassembly with plently of pictures and notes. I'm guessing there are similarities between the 24s and 22s in '67 so if I can help you out in anyway with info, let me know!Diane
