Old 08-14-2016, 10:12 AM   #1
1972 23' Safari
Tonka Bay , Minnesota
Build a new dinette
This week I fulfilled a my dream of an Airstream purchased a 1972 Safari. My husband and I would like to replace the front pull out sofa with a dinette. We are thinking a "U" shape option or possibly just benches with a table in the middle. If anyone has done this, I would appreciate any input. Lessons learned, dimensions, photos of your projects etc.
I'm sure this is one of many questions I'll have as we continue to enjoy our new home on wheels.
Thanks!
Cheryl
Cheryl D. is offline   Reply With Quote
Old 08-14-2016, 09:24 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I did the same thing in my '74 Argosy. Can't provide dimensions as I doubt any two trailers are exactly the same. I can provide pics if you send me an email address. I have used up my photo space here.
Old 08-14-2016, 10:02 PM   #3
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I threw my old dinette out and made a new one. Like so:
ID:	269111   Click image for larger version
Old 08-15-2016, 12:54 AM   #4
Pygmypoacher's Avatar
Black Diamond , Washington
I'm finishing my renovation of a '79 Sovereign. Here's what I've built for my sitting area. Power systems are under the middle bench.
Pygmypoacher is offline   Reply With Quote
Old 08-15-2016, 05:21 AM   #5
mandolindave's Avatar
I shored up my front dinette
Also new cushions and table……
HAVE NOT USED IT ONCE !!!!!!!!!!
I like eating outside.
mandolindave is offline   Reply With Quote
Old 08-15-2016, 11:57 AM   #6
1969 27' Overlander
Sun Lakes , Arizona
Cheryl,
We want to do the same to our AS. I wish I could offer some advise but like you we're still in the planning phase. I'm actually posting here so that I can see other replies and get ideas.
Great question thanks - See you on the open road
Tony and Irene
Huck the Mutt and Finn too
69 Overlander - Sentimental Journey
2015 Tundra - Rig-O-Tony
Sun Lakes, AZ
WBCCI 2876
Redleger is offline   Reply With Quote
Old 08-15-2016, 12:03 PM   #7
1969 27' Overlander
Palm Desert , California
Hey Pygmypoacher,
Your photos would be most helpful for my own renovation. Any chance you that they are available in larger format than on the forum? Thanks.
DesertRat223 is offline   Reply With Quote
Old 08-15-2016, 12:22 PM   #8
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
I was going to do a U-shaped dinette, but decided against it. The table is much more secure when attached to the front wall rather than two wobbly posts. It's difficult to slide all the way around, then realize you forgot the salt.
Those are super-sized slide out drawers under the seating that can fit an airline-bin-max suitcase. Everything is built from 3/4" Eurolite marine ply, with cherry accents. Table is Lagoon Alabaster veneer, with wenge and aspen. I like the folding side leaves; much easier to get in and out during the daytime. The ledge near the open window hides the flatscreen TV (see this thread: http://www.airforums.com/forums/f317...ml#post1830709 )
Looking back, I wish that I'd sloped the drawer faces backwards, to give more heel room. If someone comes in with hiking boots, they leave lots of black marks on the drawers. I was also trying to make my cushions as large as possible, which was a mistake. A smaller cushion that is directly attached to the hatch lid is easier to lift up and get stuff out from under it. I rarely use the forward lockers because it's such a hassle.
Name:	2016-08-15 14.08.43.jpg
ID:	269164   Click image for larger version
Name:	2016-08-15 14.09.25.jpg
SuzyHomemakr is offline   Reply With Quote
Old 08-15-2016, 12:31 PM   #9
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
This is what we came up with in our '74 Sovereign. The space does not convert into a bed, we had that in our '64 Overlander and got tired of changing it back and forth so for this trailer we incorporated enough sleeping for 6 in the rear and had a dedicated dining area. This table is comfortable for 6 adults, and you could fit 8 or 9 if need be.
The table has a core of pine and resin impregnated honeycomb cardboard. Benches were framed with 2x2s with 1/8" Baltic Birch plywood fronts. Here's a photo with the table removed. The panel under the front bench is held in place with a magnet for easy access to that space for things not often used. There's also access to the umbilical wire connections. The strips on the front of the plywood were added recently to try to minimize the scuff marks from shoes.
Next photo shows the swing-out drawer under the street side bench. It pivots on hinges at one end and runs on a couple of ball casters across the front.
The balls run on strips of aluminum on the bottom of the drawer to prevent the plywood bottom from wearing. We usually keep folding chairs in here.
Long drawers under the curb side bench are easily accessible from outside.
Initially I attached the vinyl to the back of the seats, but had trouble getting them tight against the "deck" behind the benches. Recently I redid them with strips of wood to hold them down. Not the most elegant solution but cheap and easy. I'm sure a professional upholsterer would be able to do better!
We took a month-long trip with the table in place but without the laminate on it as the laminate had been ordered but didn't come in on time. This turned out to be a blessing in disguise as we found that the table was about 2" too big in each direction. It was hard to know this until we'd used it for a few weeks. I was able to easily cut it down since the laminate was not yet installed. The other good thing about all this was that Lowes didn't charge for the laminate because they messed up the order.
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
1965 Avion C-10 Truck Camper (65avion.home.blog)
DavidsonOverlander is offline   Reply With Quote
Old 08-15-2016, 12:49 PM   #10
Toddzilla's Avatar
1958 17' Pacer
Damascus , Oregon
We are just finishing the build out of our 1958 Pacer.
We head to our first Rally this coming weekend......soooooo excited.
Leather seat cushions to follow.
1/2" & 3/8" Baltic Birch Ply for full build.
The Dog House - https://www.airforums.com/forums/f104...er-111301.html
Toddzilla is offline   Reply With Quote
Old 08-15-2016, 01:00 PM   #11
Originally Posted by DesertRat223 View Post
Hey Pygmypoacher,
PM me your personal email. I'll send full size pics.
Old 08-15-2016, 01:31 PM   #12
1972 31' Sovereign
Houston , Texas
Toddzilla, I like the insulator turned pendant light. How did you make the hole in the glass?
BayRat is offline   Reply With Quote
Old 08-15-2016, 01:31 PM   #13
1972 25' Tradewind
fort lauderdale , Florida
Grant,
I really like your design but your first pic is the only one visible. Could you please re-attach.
thank you
ERic
ehodg66 is offline   Reply With Quote
Old 08-15-2016, 03:38 PM   #14
bigfoot390's Avatar
1999 30' Excella 1000
Chatham , Virginia
Dinette
We are in the process of making our dinette a comfortable 2 seater rather then a a tight 4. Gives us 10" more floor space in the kitchen. Pictures coming.
bigfoot390 is offline   Reply With Quote
Old 08-15-2016, 06:22 PM   #15
1964 26' Overlander
Milton , ON
Originally Posted by ehodg66 View Post
Grant,
thank you
ERic
Sorry about that, here's the post again. If a moderator sees this, feel free to delete my previous post.
Long drawers under the curb side bench are easily accessible from inside or standing outside in the doorway.
Initially I attached the vinyl to the back of the seats, but had trouble getting them tight against the "deck" behind the benches. Recently I redid them with strips of wood to hold the vinyl down. This allowed me to screw through the backs of the benches before final attachment of the vinyl. Not the most elegant solution but cheap and easy. I'm sure a professional upholsterer would be able to do better!
This project would have been much easier if we hadn't needed the space provided by the wrap-around bench! That adds a lot of complication in construction of the bench backs and making everything fit.
1974 Sovereign
TAC ON-5
Old 08-15-2016, 06:55 PM   #16
Toddzilla's Avatar
1958 17' Pacer
Damascus , Oregon
Glass drill bit in a drill press and squirt it with water.
Old 08-15-2016, 07:14 PM   #17
1964 26' Overlander
Milton , ON
That is a very cool light! Do you have a way of keeping it from swinging when you're travelling, or does that matter?
1974 Sovereign
TAC ON-5
Old 08-15-2016, 10:13 PM   #18
Toddzilla's Avatar
1958 17' Pacer
Damascus , Oregon
I created a hook above the front window and we put a sock over it.
Old 08-16-2016, 02:55 PM   #19
1976 25' Tradewind
Kimberton , Pennsylvania
The PO removed the gaucho sofa/bed from the front of our 25’ TW to replace the flooring. She found that a standard IKEA sofa/bed (click-clack like the gaucho) fit easily into the space. The stretchers on the frame make for a more comfortable sleeping surface than the solid plywood base of the old AS gaucho. I recently bought a recycled pizza shop two seat dinette that I find useful for one or two travelers who would sleep on the gaucho midship and on a cot if nec. set up forward. I’m going to attempt attaching photos of the two. If they don’t appear in this thread then look for them in the gallery.
BicenTw is offline   Reply With Quote
Old 08-17-2016, 06:39 AM   #20
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Check out Bruce's post:
http://www.airforums.com/forums/f38/...ld-140250.html
Greg1410 is offline   Reply With Quote
Build dinette for 2005 Safari TinyTin Cabinets, Counter Tops & Furnishings 17 01-19-2023 06:22 AM
Dinette Modification to couch/dinette wmcmi_528 2002 - 2005 International 8 10-22-2014 08:27 AM
ISO or How to build Front Dinette Ashleya General Repair Forum 3 07-28-2014 07:19 PM
How to build a dinette lucymcdog Cabinets, Counter Tops & Furnishings 78 08-15-2011 10:03 AM
wanna build new gaucho John Greenlee Cabinets, Counter Tops & Furnishings 2 03-26-2004 05:18 PM
