Old 08-15-2016, 06:22 PM   #15
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Originally Posted by ehodg66 View Post
Grant,
I really like your design but your first pic is the only one visible. Could you please re-attach.
thank you
ERic
Sorry about that, here's the post again. If a moderator sees this, feel free to delete my previous post.
This is what we came up with in our '74 Sovereign. The space does not convert into a bed, we had that in our '64 Overlander and got tired of changing it back and forth so for this trailer we incorporated enough sleeping for 6 in the rear and had a dedicated dining area. This table is comfortable for 6 adults, and you could fit 8 or 9 if need be.
The table has a core of pine and resin impregnated honeycomb cardboard. Benches were framed with 2x2s with 1/8" Baltic Birch plywood fronts. Here's a photo with the table removed. The panel under the front bench is held in place with a magnet for easy access to that space for things not often used. There's also access to the umbilical wire connections. The strips on the front of the plywood were added recently to try to minimize the scuff marks from shoes.
Next photo shows the swing-out drawer under the street side bench. It pivots on hinges at one end and runs on a couple of ball casters across the front.
The balls run on strips of aluminum on the bottom of the drawer to prevent the plywood bottom from wearing. We usually keep folding chairs in here.
Long drawers under the curb side bench are easily accessible from inside or standing outside in the doorway.
Initially I attached the vinyl to the back of the seats, but had trouble getting them tight against the "deck" behind the benches. Recently I redid them with strips of wood to hold the vinyl down. This allowed me to screw through the backs of the benches before final attachment of the vinyl. Not the most elegant solution but cheap and easy. I'm sure a professional upholsterer would be able to do better!
This project would have been much easier if we hadn't needed the space provided by the wrap-around bench! That adds a lot of complication in construction of the bench backs and making everything fit.
We took a month-long trip with the table in place but without the laminate on it as the laminate had been ordered but didn't come in on time. This turned out to be a blessing in disguise as we found that the table was about 2" too big in each direction. It was hard to know this until we'd used it for a few weeks. I was able to easily cut it down since the laminate was not yet installed. The other good thing about all this was that Lowes didn't charge for the laminate because they messed up the order.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is offline   Reply With Quote
Old 08-15-2016, 06:55 PM   #16
Toddzilla's Avatar
1958 17' Pacer
Damascus , Oregon
Originally Posted by BayRat View Post
Toddzilla, I like the insulator turned pendant light. How did you make the hole in the glass?
Glass drill bit in a drill press and squirt it with water.
The Dog House - http://www.airforums.com/forums/f104...er-111301.html
Toddzilla is offline   Reply With Quote
Old 08-15-2016, 07:14 PM   #17
1964 26' Overlander
Milton , ON
That is a very cool light! Do you have a way of keeping it from swinging when you're travelling, or does that matter?
Grant Davidson
Milton, ON
1946 Spartan Manor
1964 Overlander
1974 Sovereign
TAC ON-5
Old 08-15-2016, 10:13 PM   #18
Toddzilla's Avatar
1958 17' Pacer
Damascus , Oregon
I created a hook above the front window and we put a sock over it.
Old 08-16-2016, 02:55 PM   #19
1976 25' Tradewind
Kimberton , Pennsylvania
The PO removed the gaucho sofa/bed from the front of our 25’ TW to replace the flooring. She found that a standard IKEA sofa/bed (click-clack like the gaucho) fit easily into the space. The stretchers on the frame make for a more comfortable sleeping surface than the solid plywood base of the old AS gaucho. I recently bought a recycled pizza shop two seat dinette that I find useful for one or two travelers who would sleep on the gaucho midship and on a cot if nec. set up forward. I’m going to attempt attaching photos of the two. If they don’t appear in this thread then look for them in the gallery.
BicenTw is offline   Reply With Quote
Old 08-17-2016, 06:39 AM   #20
1973 23' Safari
1970 27' Overlander
Boerne , Texas
Check out Bruce's post:
http://www.airforums.com/forums/f38/...ld-140250.html
Greg1410 is offline   Reply With Quote
Old 08-17-2016, 08:09 AM   #21
1972 23' Safari
Tonka Bay , Minnesota
As I mentioned, I'm new to this. How do I find the gallery? Thanks!
Cheryl D. is offline   Reply With Quote
Old 08-18-2016, 08:23 PM   #22
1976 25' Tradewind
Click on my name BicenTw next to my comment then in the drop down menu click on View Gallery Uploads. You’ll see two photos; the photo of the bed frame in the AS and of the dinette on the driveway.
Old 08-19-2016, 08:01 PM   #23
1975 Argosy 26
Stockbridge , Georgia
I'd love to see the pics of the dinette as well, please. We just purchased a 74 Argosy. laracohran@gmail.com Thanks!
laracohran is offline   Reply With Quote
Old 08-19-2016, 08:07 PM   #24
1975 Argosy 26
I'd love to see the pics as well, please. We have a 74 Argosy. My email is laracohran@gmail.com Thanks!
Old 08-28-2017, 11:16 AM   #25
bigfoot390's Avatar
1999 30' Excella 1000
Chatham , Virginia
Our dinette. Click image for larger version
ID:	293455Click image for larger version
bigfoot390 is offline   Reply With Quote
Old 08-28-2017, 11:21 AM   #26
bigfoot390's Avatar
Chatham , Virginia
We shortened it up to only seat 2 to give us more floor space. My wife did the floor, tile and upholstery. I did the carpentry work to shorten up everything.
Build dinette for 2005 Safari TinyTin Cabinets, Counter Tops & Furnishings 16 01-31-2015 10:22 PM
Dinette Modification to couch/dinette wmcmi_528 2002 - 2005 International 8 10-22-2014 08:27 AM
ISO or How to build Front Dinette Ashleya General Repair Forum 3 07-28-2014 07:19 PM
How to build a dinette lucymcdog Cabinets, Counter Tops & Furnishings 78 08-15-2011 10:03 AM
wanna build new gaucho John Greenlee Cabinets, Counter Tops & Furnishings 2 03-26-2004 05:18 PM
