04-19-2010, 04:49 PM
1973 21' Globetrotter
Belen
, New Mexico
Brushed Aluminum Tambour
Has anybody out there had any experience in replacing the faux wood tambour in their cabinets with "brushed aluminum tambour"? And if so, which vendor did use or do you suggest?
04-19-2010, 06:05 PM
2010 27' FB International
Birmingham
, Michigan
The best aluminum tambour is available from Wilson Art. Great material. As with all tambour...you need experience cutting.
04-19-2010, 06:23 PM
1993 34' Excella
Estancia
, New Mexico
I have seen the "faux wood" sprayed with hardware store paint and IMHO it looked durn good. But take that with as much salt as necessary. I actually like the "faux".
04-19-2010, 09:15 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Where? I can't find tambour anywhere at their website. I used Wilsonart HD laminate on my credenza and dinette tops. Great stuff. I see the Decorative Metals info, but nothing about tambour anywhere there either.
Vaughan
04-19-2010, 10:02 PM
Maniacal Engineer
Lopez Island
The "Classic Rides" on youtube that describes replacing one's old tambour doors w/ Aluminum apparently used these folk's stuff.
- Bart
04-20-2010, 08:29 AM
Belen
, New Mexico
Metal Tambour
We saw that youtube video of replacing wood for metal tambour, that's where we got the idea of doing it to ours. But with Omega National all I saw in metal tambour was the Fennel and it only comes in interlocking slats as far as I could see. We wanted a sheet like they were using in the video. Spoke with a gal from Tapease but she didn't know if there's would be "heavy duty" enough for cabinets. Says it more for decorative. I will check out the Wilson Art tambour though....
04-20-2010, 10:20 AM
Maniacal Engineer
Lopez Island
Winona Manufacturing is the company they had in the credits on the video; their website redirects to Omega National Products. The part
number I think you want is:
1/2" brushed aluminum (over hardboard): 6256-801
You may need to contact the company to find a distributor that stocks this material. I've never dealt w/ these folks.
- Bart
04-20-2010, 10:37 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Outwater Plastics also carries it here. I've not order this from them, but many other iteams and they are great to work with...
Shari
04-21-2010, 08:09 AM
Belen
, New Mexico
Metal Tambour
Thanks for all your help. I'll check out both those sites and let you know. I believe I already checked with Omega and was referred to Louis & Company (local vendor) and they're supposed to send me out samples.
Barb
04-23-2010, 05:14 AM
1962 22' Safari
2014 30' Flying Cloud
Grayling
, Michigan
Safari62 Always looking for the silver lining in the gray clouds...
04-23-2010, 08:26 AM
Loganville
, Georgia
I need to replace mine under the sink. I have been really busy and have not had time to evaluate the job. I checked out classic rides but I need to know how to get it out under the sink
Brian
Brian & Adrienne
02-25-2012, 09:54 AM
1970 27' Overlander
Summit
, Mississippi
Finding this aluminum tambour like used in the classic rides video has become next to impossible. Everywhere I look lists this stuff as decorative only and says not to be used as a door. It appears that one must buy the decorative only sheets and use it as a door anyway but it is hard to plop down that much money and not know for sure. This is one question that does not seem to have a clear cut answer. It would seem that someone would simply know whether or not classic rides used the decorative only or not because it sure worked for them.
02-25-2012, 10:44 AM
1967 17' Caravel
Pocatello
, Idaho
Tambour
Speaking out of complete ignorance, so maybe you should completely ignore this: the plastic/laminate tambour used by A/S and the oak (real wood strips) on my Hoosier's roll-up door has what looks like a heavy canvas backing glued on that keeps the strips together and makes it flexible to roll up and down around a roller of some kind.
Does your expensive alum tambour have this flexible backing? And maybe the mfr nixed it as a door because it needs more strength on the backing? Or maybe the mfr's "door" was imagined by them to be much bigger? Can you call a mfr's rep and talk to someone about your prospective use vs. their possibly CYA blanket statement?
Dunno. Just some thinking points...
Vivian
02-25-2015, 08:10 PM
1975 31' Sovereign
howell
, Michigan
Brushed aluminum tambour
Anyone find a good source for aluminum finished tambour that can be used for doors?
02-26-2015, 06:07 PM
1975 31' Sovereign
howell
, Michigan
Bump: anyone?
02-26-2015, 06:53 PM
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
I'd start with an Airstream dealer if you like the look of the aluminum tambour in the Sterling.
Lance
02-27-2015, 08:11 PM
1975 31' Sovereign
howell
, Michigan
Not farmilar with the Sterling, is that a new model of AS? Found a source today but is $390 plus shipping for a 4x8 sheet.
