Old 10-13-2013, 12:26 PM   #1
pt1949's Avatar
1992 29' Excella
LAS VEGAS , Nevada
Bedroom table - HELP!
Taking everything out of back to redo floor and can't get the little table in the middle out. Got all screws out on sides but is no releasing - something in middle holding on. Can't get drawers out as stop screw is turning when I try to take nut off. Can't see what is holding it on - help!
pt1949 is offline   Reply With Quote
Old 10-13-2013, 02:34 PM   #2
Smokeydog's Avatar
Gonzalez , Florida
My Avion has screws from the rear hatch. Open it up and look around you might find a screw or two.
Smokeydog is offline   Reply With Quote
Old 10-13-2013, 03:17 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I had an '86 Sovereign with the rear bedroom. Are you talking about the nightstand? I removed mine too. There were screws not only on the sides, but inside the back (and front if I recall correctly) too. You have to remove the drawers to get at them. Good luck!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
