Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 10-21-2004, 07:45 AM   #1
Profile:
Bathroom Removal
How difficult will it be to remove the fiberglass fixtures for someone who has above average carpentry skills? Has anyone done this and would you do this again? The fixtures need refinishing which I would attempt to do myself. I'm interested in all ideas. Thanks.
Keyholeren is offline   Reply With Quote
Old 10-21-2004, 09:07 AM   #2
The Painted Pig
Moonshot's Avatar
Profile:  1979 Argosy Minuet 7.3 Metre
East Central , Alabama
Images: 14
They can often be refinished while left in the camper.
I did some light sanding on mine with decent results. Also, Kevin (Overlander64) has refinished his bathroom and the pics look great. Hopefully, he'll chime in here....
Moonshot is offline   Reply With Quote
Old 10-21-2004, 09:35 AM   #3
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Have you gotten a good look under the bathroom, ie the floor. If its in good condition (unlikly for a 35 year old AS) then I'ld do them in place. Otherwise I'ld remove and fix the floor. Seems different years and models have different tricks to taking them apart. Others here have done so. I the long run it's worth doing well if you plan on keeping the trailer.
SOFI Member
Over59 is offline   Reply With Quote
Old 10-21-2004, 10:06 AM   #4
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Bathroom Removal
Greetings Keyholeren!
I agree with Moonshot and Over59 - - if your coach doesn't need floor repairs, removing the bath fixtures open the door for many more problems - - even with very careful removal, it would be possible to damage the components being removed as well as those surrounding the fixtures being removed. My bath was professionally refinished while in-place at a cost of slightly less than $400 by a local bath refinishing firm that was recommended by my regular plumbing contractor - - the results were quite satisfactory and have whitstood two seasons plus of use with no degredation to the appearance. The before photo is below - - part of the reason for my refinish was a desire to change the color from the Avacado Green:
The after photo below shows the results of the refinish's color change to Antique Pewter:
According to my refinisher, the task of refinishing the Airstream wasn't that much different from his usual home improvement jobs - - the only difference being was that spraying requred a few more "gymnastics" that usual - - the trade-off was that the Airstream was at his workshop where he had immediate access to all of his tools and supplies.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 10-21-2004, 12:23 PM   #5
Profile:
Thanks for the info. I've got the old carpeting up and the floor appear to be okay. I'll probably heed your advice and leave it in place.
Old 11-06-2004, 05:44 AM   #6
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Bathroom refinish
Kevin
Do you know the product that was used. Your pics are not showing up do you still have them available?
I have been working on my bath and looking for ideas? Unfortunaltly I may have to remove the fixtures to get at the floor.
balrgn is offline   Reply With Quote
Old 11-06-2004, 08:12 AM   #7
Anna , Illinois
Images: 156
Bathroom Removal
Greetings balrgn!
The link to the photos is updated and seem to be working.
The product that the professional refinisher used on my bathroom was proprietary (sold only to franchised installers) epoxy. All of my records are currently packed following my recent move so I can't even find the name of the franchise that provided the products.
Kevin
Kevin D. Allen
AIR #827
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 09:01 AM
61 Caravel Bathroom kayelm Sinks, Showers & Toilets 3 09-07-2004 08:17 AM
advice wanted for bathroom sink replacement Shelby Copeland Sinks, Showers & Toilets 8 12-25-2003 08:06 AM
Pergo in the bathroom Chuck Floor Finishes 8 08-05-2003 06:13 PM
bathroom compartment - removal? Cruiser General Interior Topics 7 05-16-2003 08:24 PM
