Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 02-06-2008, 02:27 PM   #1
Profile:  1978 31' Sovereign
Merlin , Oregon
Attaching cabinets to Airstream
Just wondering what is the best way to begin on installing new cabinets. I am looking at a completely gutted airstream and fairly limited cabinet building skill. Are there any semi-prefabricated options? Is the aluminum runners with wood inserts (what was originally installed) the way to go? Or is there a better way of attaching cabinets to the walls? Not tackling the overhead storage yet, just around the sink/stove/furnace etc. Any help would be so great. Thanks
spanky1313 is offline   Reply With Quote
Old 02-06-2008, 02:37 PM   #2
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
The base cabinets in ours are primarily screwed to the floor. There are a few screws into the side walls, but mostly the floor and each other. The one thing you have to be most careful about, is adding too much weight with new cabinets - all the originals are/were VERY lightweight, not like typical residential cabinets at all.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 02-06-2008, 02:43 PM   #3
Merlin , Oregon
Thanks for that advice. Is the thin plywood still the best option? And I'm also wondering in terms of laying a new floor if it would be better to install the new floor and then do the cabinets, or vice versa. I hope by now my greeness is shining through!
-kyle
Old 02-06-2008, 02:49 PM   #4
InsideOut's Avatar
1956 22' Safari
Images: 87
Yes, thin 3/16-1/4" plywood should be fine.
Depends on the floorcovering - In ours, the marmoleum is run under the cabinets just like it was done originally - makes for a clean "bottom shelf". I wouldn't run carpet or thick wood/laminate floors under them though. Carpet would be too tough to replace later and wood floors would add too much weight.
Shari
Old 02-06-2008, 02:56 PM   #5
Merlin , Oregon
Muchas Muchas Gracias!
Old 02-06-2008, 04:19 PM   #6
jdalrymple's Avatar
Profile:  1981 31' International
Siloam Springs , Arkansas
At places where the cabinet walls need more than basic screwed to the walls support, such as room dividing bulkheads, AS riveted light aluminum angle to the interior wall of the trailer to provide a rigid mounting edge for the plywood.
Jeff
'81 International 31'CB
'03 2500HD Chevy Duramax w/improvments
WBCCI #7026 Air #17054
Bellypan re-attaching chalcedon Belly Pans & Banana Wraps 30 06-21-2009 02:48 PM
Care and feeding of the tambour doors on Airstream cabinets briandeacon Cabinets, Counter Tops & Furnishings 2 07-12-2007 08:25 AM
Attaching bulkhead guy99 General Interior Topics 18 12-11-2006 05:34 PM
site that sells modern cabinets etc. for airstream Judy Barde Sinks, Showers & Toilets 1 10-17-2006 10:24 PM
Re-attaching cabinets to the interior skin. Andy R Cabinets, Counter Tops & Furnishings 5 04-07-2002 03:54 PM
