Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 04-09-2006, 07:26 PM   #1
cameront120's Avatar
Profile:  1972 25' Tradewind
Anyone with a 1972 model with front couch/bed? Help Please.
If anyone has a 1972 Tradewind or other model with a front converta-bed couch, would you mind taking a picture of it from above without the cushions? I'd really like to see how the assembly is fastened to the floor and trailer body. Mine is very loose/wobbly and the structure seems inadequate...not sure it was put together properly after being re-upholstered by the previous owner. Thanks very much!
Cheers!
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 04-09-2006, 07:55 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Cheers!
You've got the aluminum framed pullout sofa/bed ( goucho). It has aluminum extrusions around the front, with tambour doors.
I suggest you take off the plywood from the top, take out all the sliding bins and look for missing screws. It is quite simple, really. The one in my 1971 was quite solid.
Uwe
www.area63productions.com
Old 04-09-2006, 09:35 PM   #3
The rear of the goucho (front of trailer) is attached to a vertical piece of wood at each corner. These offer no rigidity whatsoever. The corners of the aluminum frame were then screwed directly into the interior skin, but these have come loose and probably didn't do a very good job of offering any kind of structural integrity. I can probably create some wood brackets that would anchor the entire assembly solidly to the floor.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 04-09-2006, 09:41 PM   #4
uwe
418
uwe's Avatar
Images: 41
I never had much trouble with my front goucho, but the side gaucho ( very similar in construction) came loose from the wall.
I drilled the attachment strips and tripled the amount of rivets, and made sure that two rivets went into the vertical ribs, for extra strength. No more issues after that.
I imagine that the front goucho can be reinforced similarly, and yes, a few modifications might be in order. No rules there.
Uwe
Old 04-09-2006, 10:07 PM   #5
Can you please describe the "attachment strips"? Mine has nothing that could be described as an attachment strip. Perhaps this is the missing piece to the puzzle!
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 04-09-2006, 11:06 PM   #6
uwe
418
uwe's Avatar
Images: 41
There is a long C-channel attachment at the rear of the side goucho, which ripped out of the skin once in my 71. That was when I did the repair with the additional rivets.
The front goucho in my 71 had the same c-channel attachment ( strip is a poor choice of words, really) but due to the curvature, it was attached differently. I am thinking that your trailer should be similar?
Uwe
Old 04-09-2006, 11:24 PM   #7
There is a rear channel that supports the slider channels of the fold out. This doesn't follow the curvature of the interior skin but is straight and parallel to the front of the couch. It was attached to the interior skin of the trailer with one screw at each end. It sounds as though I might be missing some pieces.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
WANTED: Front Dinette Photos InsideOut General Interior Topics 21 01-12-2007 04:09 PM
1974 excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 02:53 PM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 10:13 PM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 12:11 PM
Cushion Dimensions, Front Sofa Alan and Julie General Interior Topics 2 08-05-2002 03:14 PM
