Old 04-28-2015, 10:59 AM   #1
1969 31' Sovereign
Hoffman Estates , Illinois
Another U Shaped Dinette
Hi everone. ive been a forum member for several years and have gotten invaluable information here for my 69 Sovereign which need deck and frame repairs and all the systems except for electrical replaced.
So, my first post heres my just finished dinette. My goal was to keep the vintage style, and above all keep it functional.
I decided it would be much eaiser to buy the cushions first, and build the benches to fit. The frame is stick construction with 1/8th inch ply. The curves corners were framed with 1/2 inch ply radiused with a router jig. The benches are attached to the floor with wood screws. The backrests are attached to the benches but not attached to the walls. I hate putting holes in the walls.
ID:	237294   Click image for larger version
ID:	237296   Click image for larger version
Name:	2015-03-21 16.36.00.jpg
br123reed is offline   Reply With Quote
Old 04-28-2015, 11:33 AM   #2
1969 31' Sovereign
Here's the corner construction. I Carefully bent the ply around the corner and glued.
The curves on the backrests were more tricky. I had to sand off the inside layer of ply and placed it over a layer of wood filler to make it solid.
Old 04-28-2015, 12:22 PM   #3
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
That is a beautiful job. Like the color of the wood, the choice of fabric and the table. Also like the shelf top in the 9" gap under the window. Nice work
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 04-28-2015, 12:36 PM   #4
65will
65will's Avatar
1969 25' Tradewind
Greenwich , New York
looks Great
Hello, This looks great. Is your water tank and pump under it? and do you have acess to them? Thought about this for my 69 Trade Wind. Thanks
65will is offline   Reply With Quote
Old 04-28-2015, 01:24 PM   #5
1969 31' Sovereign
The tank and pump are behind the back bench. The picture of the dinette without the cushions shows the top of the water tank- the white rectangular strip. I cut the back of the seat out to steal an extra inch.
The origional water tank was missing when I got the coach so i had to go aftermarket. The water pump can be reached through the bench lid.
Old 04-28-2015, 01:46 PM   #6
1961 28' Ambassador
Mesa , Arizona
In closer look I see the tank. Good to know as we will need to put on in our 65 TWind some day.
Hittenstiehl
Old 04-29-2015, 08:28 PM   #7
Beautiful work!
Old 04-29-2015, 09:06 PM   #8
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
U-Shaped Dinette
Very nicely done from design to fulfillment.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 04-29-2015, 09:16 PM   #9
1969 31' Sovereign
Thanks for the kind words. Heres a entertainment cabinet I'm working on. I tried to do a rounded corner on it too, but the radius was too tight and split on the larger piece. I went with a 45 on the corner instead.
Old 04-30-2015, 04:07 AM   #10
Rhino33's Avatar
1980 31' International
Cincinnati , Ohio
As we are currently working on building a U shaped dinette in our 1980 International, this is beautiful!! Now that we are getting to the point of making the cushions, I envy you for the idea of working from the cushions to the dinette!
You should be very proud!!
Jenn & Robb & our two furry kids
Maizie ('the Black Dog') & Dex ('the Brown Dog')
1980 International 31
WBCCI #4447
AIR #70157
Rhino33 is offline   Reply With Quote
Old 04-30-2015, 05:53 AM   #11
1981 31' Excella II
New Market , Alabama
Looks nice where did you get the cushions? I am cheap an don't want to spend $1000 on cushions.
Perry
Old 04-30-2015, 07:16 AM   #12
1969 31' Sovereign
Thanks, I got the cushions on ebay. $189+60 for shipping. The box was huge.
The seller I used doesn't have any more cushions listed but there are some others.
Old 04-30-2015, 08:56 AM   #13
aquinob's Avatar
Portsmouth , Virginia
Very nice work. You got a great deal on the cushions, smart to design the cabinetry around them so you save what for most folks would be the expensive part.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 05-01-2015, 08:40 AM   #14
Carrollton , Kentucky
Outstanding!
Was just talking with my wife about replacing our couch with a u-shaped dinette. Thanks for sharing your design!
MichaelS is offline   Reply With Quote
2014 Flying Cloud 23FB - Fixed U Shaped Dinette campadk 2009-2015 Flying Cloud 30 05-19-2016 08:12 AM
Great progress on new U-shaped dinette ddruker 1999 Safari 30 05-07-2016 08:10 PM
Need to replace gaucho with U-shaped dinette gettysburg General Interior Topics 39 05-11-2015 07:29 AM
Dinette or L shaped living Room trogers713 Cabinets, Counter Tops & Furnishings 3 10-28-2003 10:11 PM
Vintage Oval Shaped LP Tank Cover smily LP Gas, Piping, Tanks & Regulators 3 12-20-2002 04:52 PM
