Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Cabinets, Counter Tops & Furnishings
Old 05-31-2002, 04:26 PM   #1
melprice's Avatar
Profile:
Aluminum Trim Source?
Does anyone know of a source for aluminum trim. I want to build new cabinets and would like to edge them in aluminum.
What I really want to do is hand form sheet aluminum into the "L" and "U" profiles I need to but I have no skills in cutting or forming. A link to basic aluminum working skills would be appreciated.
The sort of trim I'm looking for is in this picture around the counter tops.
Thank you in advance.
Melvin and Sheila
1972 Trade Wind
Cleveland, OH
melprice is offline   Reply With Quote
Old 06-14-2002, 12:31 AM   #2
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
melprice;
Here are 2 sources for RV trim and moldings.
http://all-rite.com/trimmoldings.html
http://www.tapeease.com
Regards;
-BobbyWright
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 07-20-2002, 12:38 AM   #3
Cat
Cat's Avatar
Profile:  Mukilteo , Washington
Images: 8
Send a message via Yahoo to Cat
Aluminum Trim
I chose ALUMINUM T-Trim "Moulding"...and the outlet I used was:
J.H. Carr & Sons in Seattle, Washington. Their phone number is Area Code 206..763-1937.
The trim I used is "T-Trim"...not glue-on, and not screw on. It comes in 14-foot lengths, and 1-1/4 inches in width, so the edge it's been installed on needs to be able to accommodate it.
(I have 2 tables in the Salon, that are hinged together. that I desperately wanted trimmed in this 1-1/4 inch T-Trim..so in order to use the trim on them, the AIRSTREAM Stainless Steel hinges HAD to be 'reset' OFF-CENTER to accommodate the thicker tables.)
The lengths are 'rigid', so installation has to be sometimes done "off-site" to go around curves.
It is not easy to install, so not for the 'faint of heart'.
A special note: It does not have to be mitred, screwed or 'glued'.
.......Cat
*Cat's Vardo "Bear" (1981-32ft.Excella)
http://autos.groups.yahoo.com/group/RoyalTrailerTrash[/u] to meet good people in good Parks[/i]
Cat is offline   Reply With Quote
Old 07-22-2002, 03:16 AM   #4
Cat
Cat's Avatar
Images: 8
T-Moulding
Hopefully, my new thread of Cudtom Designs has been registered and is up . My first thread on it, is about the t-trim (aluminum). Someone posted in yours I think that they used Stainless Steel....I think I prefer the Aluminum for it's ability to bend and it's weight (lack of).
Anyway...if I didn't tell you my source, let me know...and I'll send it to you. I did post it somewhere. And the trim was installed today in the Salon and Galley...and all that's left is the dining room (double) table (2). pHOTOs will be up on the Forum by August 9th.
.....Cat
Old 09-24-2006, 11:43 AM   #5
69 Caravel
KHarris's Avatar
Profile:  1969 18' Caravel
Bayfield , Colorado
here's a good source for all things aluminum
http://www.brunnerent.com
KHarris is offline   Reply With Quote
Old 09-24-2006, 12:17 PM   #6
Spartan's Avatar
Profile:  1973 31' Excella 500
Rabun Gap , Georgia
eposiode 14 on the VAP
David Winnick used this http://www.brunnerent.com/ as the source for the aluminum trim on his 68 Caravel and the 75th anniversary edition for Airstream.
theVAp.com has an interview with him on episode 14 that you might find interesting.
Nick & Holly
1972 Excella 500
1999 Dodge 2500
AIR# 13829
"We've got a PBS mind in a MTV world"
Jimmy Buffett
Spartan is offline   Reply With Quote
Old 09-08-2009, 07:19 PM   #7
RichHog's Avatar
Profile:  1972 25' Tradewind
Houston , Texas
Has anyone replaced the T moulding that runs down the ceiling. I have 2 tracks that are about 20' with no seams on my 25' 72 Tradewind. One looks a little cracked with some surface missing
RichHog is offline   Reply With Quote
Vinyl/plastic Trim Around The Inside Of Windows Tim T Parts Archive 8 10-21-2003 04:02 PM
Straightening Bent Aluminum Trim Marshall44 Clearcoat, Exterior Paint & Trim 3 03-24-2003 08:27 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 06:49 PM
Another aluminum source 83Excella Ribs, Skins & Rivets 0 05-14-2002 12:34 PM
Aluminum & air tool source 83Excella Ribs, Skins & Rivets 0 05-11-2002 07:08 PM
